2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building RTEMS cross tools
To: <[email protected]>
Date: Mon, 28 Apr 2014 17:43:53 +0200
Hi
it would be lovely if the experts who have done stuff like that before
could help me with this one, even though this is not strictly speaking,
an EPICS matter.
My goal is to build the RTEMS cross tools from source under ubuntu. I
tried the manual procedure as described in [1], as well as the debian
source package from [2]. I tried building on 32bit Ubuntu precise, and
64bit ubuntu saucy and (lately) 64bit trusty.
The build always fails at the same point, output displayed below. Note
that in this case I built with nix (therefore the strange path names),
but it makes no difference if I do all the steps manually (/tmp/nix-
build-gcc-powerpc-rtems4.9.drv-1/ is the temporary directory with the
downloaded sources and the build-powerpc build directory).
building _fixunssfsi.o
/tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-powerpc/./gcc/xgcc -
B/tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-powerpc/./gcc/ -
nostdinc -B/tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-
powerpc/powerpc-rtems4.9/newlib/ -isystem /tmp/nix-build-gcc-powerpc-
rtems4.9.drv-1/build-powerpc/powerpc-rtems4.9/newlib/targ-include -
rtems4.9.drv-1/gcc-4.3.2/newlib/libc/include -
B/nix/store/8wd0rdxqkrbz6hacwmfihg89wriz37kn-gcc-powerpc-
rtems4.9/powerpc-rtems4.9/bin/ -
rtems4.9/powerpc-rtems4.9/lib/ -isystem
rtems4.9/powerpc-rtems4.9/include -isystem
rtems4.9/powerpc-rtems4.9/sys-include -O2 -g -g -O2 -mcpu@3 -
mrelocatable-lib -mno-eabi -mstrict-align -O2 -
I../../gcc-4.3.2/gcc/../newlib/libc/sys/rtems/include -O2 -g -g -O2   -
DIN_GCC -DCROSS_DIRECTORY_STRUCTURE   -W -Wall -Wwrite-strings -Wstrict-
prototypes -Wmissing-prototypes -Wold-style-definition  -isystem
./include   -g -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED
-Dinhibit_libc  -I. -I. -I../../.././gcc -I../../../../gcc-4.3.2/libgcc
-I../../../../gcc-4.3.2/libgcc/. -I../../../../gcc-4.3.2/libgcc/../gcc -
I../../../../gcc-4.3.2/libgcc/../include   -o _fixunssfsi.o -MT
_fixunssfsi.o -MD -MP -MF _fixunssfsi.dep -DL_fixunssfsi -c
../../../../gcc-4.3.2/libgcc/../gcc/libgcc2.c \
In file included from /tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-
powerpc/./gcc/include-fixed/syslimits.h:7,
powerpc/./gcc/include-fixed/limits.h:11,
                 from
../../../../gcc-4.3.2/libgcc/../gcc/libgcc2.c:1697:
/tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-powerpc/./gcc/include-
fixed/limits.h:122:61: error: no include path in which to search for
limits.h
make[4]: *** [_fixunssfsi.o] Error 1
make[4]: Leaving directory `/tmp/nix-build-gcc-powerpc-
rtems4.9.drv-1/build-powerpc/powerpc-rtems4.9/m403/libgcc'
make[3]: *** [multi-do] Error 1
make[3]: Leaving directory `/tmp/nix-build-gcc-powerpc-
rtems4.9.drv-1/build-powerpc/powerpc-rtems4.9/libgcc'
make[2]: *** [all-multi] Error 2
make[2]: Leaving directory `/tmp/nix-build-gcc-powerpc-
make[1]: *** [all-target-libgcc] Error 2
make[1]: Leaving directory `/tmp/nix-build-gcc-powerpc-
rtems4.9.drv-1/build-powerpc'
make: *** [all] Error 2
The offending line in /tmp/nix-build-gcc-powerpc-rtems4.9.drv-1/build-
powerpc/./gcc/include-fixed/limits.h reads:
#include_next <limits.h>		/* recurse down to the real one */
I'd very much appreciate any kind of hints as to what can be done about
this.
[1] http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node6.html
[2] http://epics.nsls2.bnl.gov/debian/
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Building RTEMS cross tools Mike Westfall
Prev: gateway Konrad, Martin
Next: Re: Building RTEMS cross tools Konrad, Martin
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Building RTEMS cross tools Mike Westfall
ANJ, 16 May 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
