2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Thu, 10 Jul 2014 23:00:48 -0000
On 07/10/2014 05:14 PM, mdavidsaver wrote:
>> In dbUnitTest.c shouldn't the Type arguments to OP use the
>>     epics{Int,UInt,Float}<n> names? If not I suspect there
>>     should at least be a couple more 'unsigned' keywords in
>>     there.
> Before I can answer this question I think you will need to
> educate me a bit about argument type promotion in vararg
> functions.  Does va_arg() have knowledge of this?  Will
> va_arg(X,short) actually return an 'int'?
No, you just educated me, I withdraw the above comment. It would be nice
to have a source-file comment nearby saying something like "See the C
integer type promotion rules" for human readers, and maybe use that
language in the header file as well.
> Just to throw out another idea.  I have considered using
> printf style syntax just to get a compile time check.  eg.
> testdbPutField("pvname", DBF_LONG, "%d", 0) where exactly
> "%d" must be used for DBF_LONG.  As a side effect this
> would work well for DBF_STRING.
True, but it might cause problems on Windows when we add 64-bit integer
fields ("%ld" vs "%lld"). I'm about to publish a branch for comments
that introduces DBF_INT64 and DBF_UINT64 types to the database.
Unfortunately it will probably break device support for waveform and
other record types that can choose field types, because I inserted the
64-bit type IDs between ULONG and FLOAT.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
ANJ, 10 Jul 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
