2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Fri, 11 Jul 2014 22:09:17 -0000
On 07/11/2014 04:06 PM, mdavidsaver wrote:
> Ok, thats it.  Barring bugs or futher requests, this is done.
The dbLockCleanupRecords() routine looks a little strange; it appears to
call free() once, on prec->lset of first record of the /second/ record
type. Now I know that dbLockInitRecords() only calls dbCalloc() once, so
all of the lockRecord (prec->lset) objects get allocated in a single
block, but the address of that big block is going to be the first record
instance of the first record type that actually has any records loaded.
I think you still need to loop through the record types, but you can
exit it as soon as you find the first record instance.
It seems to me that dbLockCleanupRecords() should also be emptying the
lockSetList[] lists, which contain lockSet objects. I admit I have no
idea what the differences are between the three different lists, but I
can see that there are calls to dbCalloc() in dbLock.c that don't appear
to an have associated call to free() anywhere.
> I decided to include dbPutLinkTest, which is stripped down since
> testing of CA links won't work yet.  dbCa isn't being initialized,
> and probably shouldn't be as this will start a CA client.
That's fine. There are several input links in dbCommon.dbd that you
could have used for testing (e.g. SDIS) though, you didn't have to add
another link to the xRecord type.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Next: Fwd: crash when clearing link field Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epicsThreadShowAll Benjamin Franksen
ANJ, 18 Jul 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
