2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Array data in db files?
To: EPICS Core-Talk <[email protected]>
Date: Mon, 18 Aug 2014 15:45:59 +0200
Just thinking aloud...
I remember a number of situations where users were complaining about not being able to set array data from within the .db file. (To specify default values for waveform or compress records.)
Right now I am facing (reviewing) design documents of device support for a very versatile card that supports routing its inputs and outputs to a multitude of PCI/PCIe backplane signals. Stuff that cries for mbbi/mbbo type records that are not limited to 16 states. If option strings, values, severities were arrays, such records might be fairly easy to implement.
Has extending the DB syntax to cover array data been considered at some point?
Cheers,
~Ralph
Re: Array data in db files? Michael Davidsaver
Prev: Re: dbcar() and dbcaStats() locking Andrew Johnson
Next: Re: Array data in db files? Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Aug 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
