2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Assertion failure in dbLock.c
To: [email protected]
Date: Mon, 06 Oct 2014 17:48:30 -0400
In addition to softMain.cpp in Base, devIocStatsSub.c will have this
problem as well.
On 10/06/2014 01:24 PM, Andrew Johnson wrote:
> The IOC database should be able to shut down an IOC, preferably by just
> calling exit() which is what the softIoc's exit subroutine record is
> doing above. In 3.14 this worked fine, but now it causes the process to
> suspend with the above message.
> Fix is not urgent, but should be made before 3.15.1.
> - Andrew
Assertion failure in dbLock.c Andrew Johnson
Prev: Jenkins build is back to normal : epics-base-3.15-win64 #92 APS Jenkins
Next: Jenkins build became unstable: epics-base-3.15 #116 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Assertion failure in dbLock.c Andrew Johnson
ANJ, 06 Oct 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
