2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DoE and EPICS
To: <[email protected]>
Date: Wed, 17 Dec 2014 11:31:51 -0600
Hi Ralph,
On 12/17/2014 01:42 AM, Ralph Lange wrote:
> ITER/CODAC is gathering ammunition for some upcoming discussions
> concerning regulation and the use of open source software - EPICS - for
> a nuclear installation.
> As far as I know, at some time in the past the DoE demanded that all
> DoE-funded projects use EPICS for controls. Is that so? Is there any
> written documentation of this - directly or as part of a committee report?
There is no such requirement, nor do I think there is ever likely to be.
I just talked to Richard Farnsworth who has been on review committees
for several DoE facilities and he said that EPICS' history makes it the
obvious default choice for many projects, but that at least one recent
DoE project has successfully justified using other software instead of
EPICS.
If you haven't already you should probably check with sites that provide
proton therapy ­treatments downstream of an EPICS control system, such
as at PSI:
    http://www.aps.anl.gov/epics/tech-talk/2008/msg00803.php
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
DoE and EPICS Ralph Lange
Prev: DoE and EPICS Ralph Lange
Next: Possible bug in ca_clear_channel Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Dec 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
