2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbl output and record name aliases
To: [email protected]
Date: Tue, 06 Jan 2015 12:47:03 -0500
I'd argue against changing the output format of 'dbl'.  It would break
too much stuff.
Would something like dbDumpRecord include what you want?  It calls
dbWriteRecordFP() which prints alias() and info().
> dbDumpRecord pdbbase
> record(ao,"LN-TS{EVR:1B}Time:Clock-SP") {
>         field(DESC,"Timestamp tick rate")
>         field(DTYP,"Obj Prop double")
>         field(UDF,"0")
>         field(FLNK,"LN-TS{EVR:1B}Time:Clock-I")
>         field(OUT,"@OBJ=EVR2, PROP=Timestamp Clock")
>         field(PREC,"3")
>         field(LINR,"LINEAR")
>         field(EGU,"MHz")
>         field(ESLO,"1.0e-06")
>         field(DRVH,"150")
>         field(HOPR,"150")
>         info("autosaveFields_pass0","VAL EGU ESLO HOPR LOPR DRVH DRVL PREC")
> alias("LN-TS{EVR:1B-DlyGen:5}Delay-SP","LN-BI{ACMI:SYS}Delay-SP")
dbl output and record name aliases Ralph Lange
Re: dbl output and record name aliases Kasemir, Kay
Prev: Re: dbl output and record name aliases J. Lewis Muir
Next: Re: dbl output and record name aliases Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbl output and record name aliases Kasemir, Kay
