2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Conversion issues (analog device support with float type raw data)
To: <[email protected]>
Date: Fri, 9 Jan 2015 13:16:40 -0600
On 01/09/2015 04:04 AM, Ralph Lange wrote:
> Does anyone have a good idea how to straighten this out in a reasonable
> and compatible way?
The API between the device support and the record type code is
completely up to the record type; the current conventions that we're
used to are not fixed in stone. There is no reason why a record type
can't provide routines for its devices to call to set the value, or to
do anything else that a device support might want to do. The prototypes
for these routines would appear as CDEFs in the Record.dbd file.
A record type can even change the device-sets-PACT => asynchronous-I/O
convention if it wants to; there's no requirement that it follow that
model, although the record must have PACT set while it's waiting for the
asynchronous completion. Changing the lock-and-call-process convention
to signal I/O completion might be a bit harder to do but not impossible,
although the record processing completion must be done in thread context
to allow things like forward linking to work properly.
The DSET and the definitions of its first 4 functions (report, init,
initRecord, getIoIntInfo) are required by the IOC and I would recommend
sticking with using the DSET for calls into the device support, but a
new record type can add anything it likes beyond the first 4 functions.
I would also encourage new record types to define their DSET as a CDEF
in the .dbd file so device supports don't have to do that.
Changing how existing record types interface is a very different issue
though, and I would suggest that we start to consider developing a new
set of standard record types instead, keeping the old ones around for
compatibility.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Conversion issues (analog device support with float type raw data) Ralph Lange
Prev: Re: Conversion issues (analog device support with float type raw data) Michael Davidsaver
Next: Build failed in Jenkins: epics-base-3.15-cyg64 #177 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
