2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win32s #1
To: [email protected]
Date: Mon, 9 Feb 2015 18:06:48 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/1/>
Started by upstream project "epics-base-3.16-win32" build number 1
originally caused by:
 Started by upstream project "epics-base-3.16-cyg64" build number 2
  Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>
[epics-base-3.16-win32] $ cmd /c call C:\windows\TEMP\hudson300200487682014328.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>make> EPICS_HOST_ARCH=win32-x86-static
make: *** No targets specified and no makefile found.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>make> EPICS_HOST_ARCH=win32-x86-static tapfiles
make: *** No rule to make target `tapfiles'.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-win32s #2 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32 #1 APS Jenkins
Next: Base 3.14.12.5 Release Timetable Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.16-win32 #3 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32s #2 APS Jenkins
