2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win64s #1
To: [email protected]
Date: Wed, 18 Feb 2015 13:33:46 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/1/>
Started by upstream project "epics-base-3.16-win64" build number 1
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>
[epics-base-3.16-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\hudson6273387914368909416.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>># HOST_OPT=NO is needed because we trigger an internal compiler error without it.
'#' is not recognized as an internal or external command,
operable program or batch file.
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static HOST_OPT=NO host
make: *** No rule to make target `host'.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static HOST_OPT=NO tapfiles
make: *** No rule to make target `tapfiles'.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Prev: Build failed in Jenkins: epics-base-3.16-win64 #1 APS Jenkins
Next: Jenkins build is still unstable: epics-base-3.14-win32 #58 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: FW: CODAC Core System 5.0.0 release announcement Ralph Lange
