2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.14.12.5-pre1 Available
Date: Wed, 4 Mar 2015 20:36:48 +0100
Hi Andrew
On Tuesday 03 March 2015 17:01:00 Andrew Johnson wrote:
> On 02/28/2015 12:14 PM, Benjamin Franksen wrote:
> > 3) fix_-re_defined-echo-in-configure_os_config_common_rtems.patch
> > We found that the RTEMS build system (we use 4.9) has its own
> > definition of ECHO, so we re-define ECHO after including them.
> Applied, but used the newer value of ECHO which is more portable.
Yes, fine.
> > 4)
> > fix_-release_cfg_config-and-_rules-should-be-in-reverse-order.patch
> > RULES and CONFIG files from the cfg subdir of other modules must be
> > included in the opposite order in which they appear in the
> > configure/RELEASE file. This is because the RELEASE file lists them
> > in reverse dependency order. This is the correct order when
> > creating search paths (because in that case earlier entries win
> > over later ones), but not when including make file snippets
> > (because in that case later entries win over earlier ones).
> You reversed the include order for the <top>/cfg/CONFIG* and
> <top>/cfg/RULES* files, but not for the <top>/configure/RULES_BUILD
> files. Wouldn't that make sense too?
I think I simply forgot this. Probably because the sequencer is the only
module we use that has its own RULES_BUILD and the definitions in there
do not overlap with those in base. But in general we can't rely on that,
so: yes, definitely.
> > 5) extend-the-cfg-mechanism-to-rules_top.patch
> > Finally one patch which adds a feature and is not a bug fix: in
> > addition to adding RULES in a support module, this allows users to
> > add TOP_RULES. In case it is not evident why this is useful, please
> > shout and I'll explain.
> I'd be interested in seeing your use-case, but I do think this is
> probably worthwhile too.
We have two separate use cases.
The first is for distributing build results to the production area. We
have a special tool named "rsync-dist" that distributes non-
destructively and allows some kind of versioning on the remote
(production) host. Since the tool requires many options to work and also
outputs a lot of text that users normally don't want to see, I have
added a few simple "TOP-only" make targets that call the tool with the
appropriate options and filters its output. This could have been done
with a wrapper script, too, but unlike shell or Perl, make does not
introduce an extra layer of quoting, which makes it a bit easier to
write such a wrapper.
The second use case is for generating cross-referenced documentation. In
this case the extra top rules trigger calls to another tool written by
another colleague that scans the source tree and generates a small tree
of cross-referenced html files, for instance about which db file is
loaded by which IOC. This doc generation step is done automatically
after everything else has been built.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Base 3.14.12.5-pre1 Available Andrew Johnson
Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
Prev: Re: Base 3.14.12.5-pre1 Available Andrew Johnson
Next: Re: Base 3.14.12.5-pre1 Available Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
