2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-cyg64 #178
To: [email protected]
Date: Tue, 10 Mar 2015 17:40:20 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/178/changes>
Changes:
[Andrew Johnson] Make TOP an absolute path when running test programs
If the test starts an IOC, the registerRecordDeviceDriver
routine will compare the absolute path of TOP at build time
against the environment variable value (normally relative)
and print a warning if they differ.
This change cleans up the .tap output from such tests.
[Michael Davidsaver] epicsAtomic: also prevent vxWorks from using posix/epicsAtomicOSD.cpp
[Michael Davidsaver] epicsAtomic: fix noop OSDs
Ensure that all are epicsAtomicOSD.cpp and use
no-op to prevent RTEMS from using the posix
implementation.
[Michael Davidsaver] epicsAtomic: fix function def. order
epicsAtomicMemoryBarrierFallback used before definition
[Andrew Johnson] Set testPlan in dbCaStatsTest.c
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12561
[Andrew Johnson] Merged Michael's fixatomiclinkage branch
[Andrew Johnson] Fixed HDEPENDS_MKMFFLAGS
[Andrew Johnson] Renamed the record test harness routine
Now named epicsRunRecordTests and as such it
matches the other test harness routines.
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12557
[Andrew Johnson] Merged revno 12549 from 3.14 branch
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12548
[Andrew Johnson] Merged revno 12546 from 3.14 branch (no changes)
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12545
[Andrew Johnson] Fix Windows builds
[Andrew Johnson] Fix Darwin build
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12540
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12530
[Andrew Johnson] Merged revno 12527 from 3.14 branch (no changes)
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12526
[Andrew Johnson] Merged revno 12517 from 3.14 branch (no changes)
[Andrew Johnson] Merged changes from 3.14 branch up to revno 12516
[Andrew Johnson] Another order-only prerequisite
[Andrew Johnson] Use order-only prerequisites for include files
This prevents unnecessary recompilations when an include
file gets regenerated.
[Andrew Johnson] Merged changes from 3.14 branch, revno 12514
[Andrew Johnson] Make .t files depend on /makeTestfile.pl
[Andrew Johnson] Fix "make tapfiles" on Windows
[...truncated 1459 lines...]
Installing generic include file ../../../include/db_field_log.h
Installing generic include file ../../../include/initHooks.h
Installing generic include file ../../../include/recGbl.h
Installing generic include file ../../../include/dbIocRegister.h
Installing generic include file ../../../include/chfPlugin.h
Installing generic include file ../../../include/dbState.h
Installing generic include file ../../../include/db_access_routines.h
Installing generic include file ../../../include/db_convert.h
Installing generic include file ../../../include/dbUnitTest.h
Installing generic include file ../../../include/dbBase.h
Installing generic include file ../../../include/dbFldTypes.h
Installing generic include file ../../../include/dbStaticLib.h
Installing generic include file ../../../include/dbStaticPvt.h
Installing generic include file ../../../include/link.h
Installing generic include file ../../../include/special.h
Installing generic include file ../../../include/guigroup.h
Installing generic include file ../../../include/devSup.h
Installing generic include file ../../../include/drvSup.h
Installing generic include file ../../../include/recSup.h
Installing generic include file ../../../include/dbStaticIocRegister.h
Installing generic include file ../../../include/dbLoadTemplate.h
Installing generic include file ../../../include/dbtoolsIocRegister.h
Installing generic include file ../../../include/epicsRelease.h
Installing generic include file ../../../include/iocInit.h
Installing generic include file ../../../include/miscIocRegister.h
Installing generic include file ../../../include/iocshRegisterCommon.h
Installing generic include file ../../../include/registryRecordType.h
Installing generic include file ../../../include/registryDeviceSupport.h
Installing generic include file ../../../include/registryDriverSupport.h
Installing generic include file ../../../include/registryFunction.h
Installing generic include file ../../../include/registryCommon.h
Installing generic include file ../../../include/registryIocRegister.h
Installing generic include file ../../../include/rsrv.h
Installing generic include file ../../../include/rsrvIocRegister.h
Installing generated generic include file ../../../include/menuConvert.h
Installing generated generic include file ../../../include/menuAlarmSevr.h
Installing generated generic include file ../../../include/menuAlarmStat.h
Installing generated generic include file ../../../include/menuFtype.h
Installing generated generic include file ../../../include/menuIvoa.h
Installing generated generic include file ../../../include/menuOmsl.h
Installing generated generic include file ../../../include/menuPini.h
Installing generated generic include file ../../../include/menuPost.h
Installing generated generic include file ../../../include/menuPriority.h
Installing generated generic include file ../../../include/menuYesNo.h
Installing generated generic include file ../../../include/menuSimm.h
Installing generated generic include file ../../../include/menuScan.h
Installing generated generic include file ../../../include/dbCommon.h
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o makeBpt.obj -c ../../../src/ioc/bpt/makeBpt.c
g++ -o makeBpt.exe  -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               makeBpt.obj    -lCom
Installing created executable ../../../bin/cygwin-x86_64/makeBpt.exe
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeBpt.exe> ../../../src/ioc/bpt/bptTypeJdegC.data bptTypeJdegC.dbd
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeBpt.exe> ../../../src/ioc/bpt/bptTypeJdegF.data bptTypeJdegF.dbd
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeBpt.exe> ../../../src/ioc/bpt/bptTypeKdegC.data bptTypeKdegC.dbd
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeBpt.exe> ../../../src/ioc/bpt/bptTypeKdegF.data bptTypeKdegF.dbd
Creating dbd file menuGlobal.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeIncludeDbd.pl> menuAlarmSevr.dbd menuAlarmStat.dbd menuFtype.dbd menuIvoa.dbd menuOmsl.dbd menuPini.dbd menuPost.dbd menuPriority.dbd menuYesNo.dbd menuSimm.dbd menuGlobal.dbd
Installing created dbd file ../../../dbd/menuGlobal.dbd
mkdir ../../../dbd
Installing created dbd file ../../../dbd/bptTypeJdegC.dbd
Installing created dbd file ../../../dbd/bptTypeJdegF.dbd
Installing created dbd file ../../../dbd/bptTypeKdegC.dbd
Installing created dbd file ../../../dbd/bptTypeKdegF.dbd
Installing dbd file ../../../dbd/system.dbd
Installing dbd file ../../../dbd/dlload.dbd
Installing dbd file ../../../dbd/dbCore.dbd
Installing created dbd file ../../../dbd/menuConvert.dbd
Installing created dbd file ../../../dbd/menuAlarmSevr.dbd
Installing dbd file ../../../dbd/menuAlarmStat.dbd
Installing dbd file ../../../dbd/menuFtype.dbd
Installing dbd file ../../../dbd/menuIvoa.dbd
Installing dbd file ../../../dbd/menuOmsl.dbd
Installing dbd file ../../../dbd/menuPini.dbd
Installing dbd file ../../../dbd/menuPost.dbd
Installing dbd file ../../../dbd/menuPriority.dbd
Installing dbd file ../../../dbd/menuYesNo.dbd
Installing created dbd file ../../../dbd/menuSimm.dbd
Installing dbd file ../../../dbd/menuScan.dbd
Installing dbd file ../../../dbd/dbCommon.dbd
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o asDbLib.obj -c ../../../src/ioc/as/asDbLib.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o asCa.obj -c ../../../src/ioc/as/asCa.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o asIocRegister.obj -c ../../../src/ioc/as/asIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbLock.obj -c ../../../src/ioc/db/dbLock.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbAccess.obj -c ../../../src/ioc/db/dbAccess.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbBkpt.obj -c ../../../src/ioc/db/dbBkpt.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbChannel.obj -c ../../../src/ioc/db/dbChannel.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbConvert.obj -c ../../../src/ioc/db/dbConvert.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbFastLinkConv.obj -c ../../../src/ioc/db/dbFastLinkConv.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbExtractArray.obj -c ../../../src/ioc/db/dbExtractArray.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbLink.obj -c ../../../src/ioc/db/dbLink.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbNotify.obj -c ../../../src/ioc/db/dbNotify.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbScan.obj -c ../../../src/ioc/db/dbScan.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbEvent.obj -c ../../../src/ioc/db/dbEvent.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbTest.obj -c ../../../src/ioc/db/dbTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o db_access.obj -c ../../../src/ioc/db/db_access.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o db_test.obj -c ../../../src/ioc/db/db_test.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o recGbl.obj -c ../../../src/ioc/db/recGbl.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o callback.obj -c ../../../src/ioc/db/callback.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbCa.obj -c ../../../src/ioc/db/dbCa.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbCaTest.obj -c ../../../src/ioc/db/dbCaTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o initHooks.obj -c ../../../src/ioc/db/initHooks.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o cvtBpt.obj -c ../../../src/ioc/db/cvtBpt.c
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbContext.obj -c ../../../src/ioc/db/dbContext.cpp
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbChannelIO.obj -c ../../../src/ioc/db/dbChannelIO.cpp
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbSubscriptionIO.obj -c ../../../src/ioc/db/dbSubscriptionIO.cpp
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbPutNotifyBlocker.obj -c ../../../src/ioc/db/dbPutNotifyBlocker.cpp
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbContextReadNotifyCache.obj -c ../../../src/ioc/db/dbContextReadNotifyCache.cpp
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o templateInstances.obj -c ../../../src/ioc/db/templateInstances.cpp
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbIocRegister.obj -c ../../../src/ioc/db/dbIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o chfPlugin.obj -c ../../../src/ioc/db/chfPlugin.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbState.obj -c ../../../src/ioc/db/dbState.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbUnitTest.obj -c ../../../src/ioc/db/dbUnitTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbServer.obj -c ../../../src/ioc/db/dbServer.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbStaticLib.obj -c ../../../src/ioc/dbStatic/dbStaticLib.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbYacc.obj -c dbYacc.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbPvdLib.obj -c ../../../src/ioc/dbStatic/dbPvdLib.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbStaticRun.obj -c ../../../src/ioc/dbStatic/dbStaticRun.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbStaticIocRegister.obj -c ../../../src/ioc/dbStatic/dbStaticIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbLoadTemplate.obj -c dbLoadTemplate.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dbtoolsIocRegister.obj -c ../../../src/ioc/dbtemplate/dbtoolsIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o epicsRelease.obj -c ../../../src/ioc/misc/epicsRelease.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o iocInit.obj -c ../../../src/ioc/misc/iocInit.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o miscIocRegister.obj -c ../../../src/ioc/misc/miscIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o dlload.obj -c ../../../src/ioc/misc/dlload.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o iocshRegisterCommon.obj -c ../../../src/ioc/misc/iocshRegisterCommon.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryRecordType.obj -c ../../../src/ioc/registry/registryRecordType.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryDeviceSupport.obj -c ../../../src/ioc/registry/registryDeviceSupport.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryDriverSupport.obj -c ../../../src/ioc/registry/registryDriverSupport.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryFunction.obj -c ../../../src/ioc/registry/registryFunction.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryCommon.obj -c ../../../src/ioc/registry/registryCommon.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o registryIocRegister.obj -c ../../../src/ioc/registry/registryIocRegister.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include    -I../../../src/ca/client     -o caserverio.obj -c ../../../src/ioc/rsrv/caserverio.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o caservertask.obj -c ../../../src/ioc/rsrv/caservertask.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o camsgtask.obj -c ../../../src/ioc/rsrv/camsgtask.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include    -I../../../src/ca/client     -o camessage.obj -c ../../../src/ioc/rsrv/camessage.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o cast_server.obj -c ../../../src/ioc/rsrv/cast_server.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o online_notify.obj -c ../../../src/ioc/rsrv/online_notify.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o rsrvIocRegister.obj -c ../../../src/ioc/rsrv/rsrvIocRegister.c
windres -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         ../dbCore.rc dbCore.coff
g++ -o dbCore.dll -shared -Wl,--out-implib,libdbCore.dll.a -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               asDbLib.obj asCa.obj asIocRegister.obj dbLock.obj dbAccess.obj dbBkpt.obj dbChannel.obj dbConvert.obj dbFastLinkConv.obj dbExtractArray.obj dbLink.obj dbNotify.obj dbScan.obj dbEvent.obj dbTest.obj db_access.obj db_test.obj recGbl.obj callback.obj dbCa.obj dbCaTest.obj initHooks.obj cvtBpt.obj dbContext.obj dbChannelIO.obj dbSubscriptionIO.obj dbPutNotifyBlocker.obj dbContextReadNotifyCache.obj templateInstances.obj dbIocRegister.obj chfPlugin.obj dbState.obj dbUnitTest.obj dbServer.obj dbStaticLib.obj dbYacc.obj dbPvdLib.obj dbStaticRun.obj dbStaticIocRegister.obj dbLoadTemplate.obj dbtoolsIocRegister.obj epicsRelease.obj iocInit.obj miscIocRegister.obj dlload.obj iocshRegisterCommon.obj registryRecordType.obj registryDeviceSupport.obj registryDriverSupport.obj registryFunction.obj registryCommon.obj re!
 gistryIocRegister.obj caserverio.obj caservertask.obj camsgtask.obj camessage.obj cast_server.obj online_notify.obj rsrvIocRegister.obj  dbCore.coff  -lca -lCom   -lpthread    -lm
ar -rc    libdbCore.dll.a        asDbLib.obj asCa.obj asIocRegister.obj dbLock.obj dbAccess.obj dbBkpt.obj dbChannel.obj dbConvert.obj dbFastLinkConv.obj dbExtractArray.obj dbLink.obj dbNotify.obj dbScan.obj dbEvent.obj dbTest.obj db_access.obj db_test.obj recGbl.obj callback.obj dbCa.obj dbCaTest.obj initHooks.obj cvtBpt.obj dbContext.obj dbChannelIO.obj dbSubscriptionIO.obj dbPutNotifyBlocker.obj dbContextReadNotifyCache.obj templateInstances.obj dbIocRegister.obj chfPlugin.obj dbState.obj dbUnitTest.obj dbServer.obj dbStaticLib.obj dbYacc.obj dbPvdLib.obj dbStaticRun.obj dbStaticIocRegister.obj dbLoadTemplate.obj dbtoolsIocRegister.obj epicsRelease.obj iocInit.obj miscIocRegister.obj dlload.obj iocshRegisterCommon.obj registryRecordType.obj registryDeviceSupport.obj registryDriverSupport.obj registryFunction.obj registryCommon.obj registryIocRegister.obj caserverio.obj caservertask.obj camsgtask.obj camessage.obj cast_server.obj online_notify.obj rsrvIocRegister.obj
ranlib libdbCore.dll.a
Installing shared library ../../../bin/cygwin-x86_64/dbCore.dll
Installing library ../../../lib/cygwin-x86_64/libdbCore.dll.a
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o ascheck.obj -c ../../../src/ioc/as/ascheck.c
g++ -o ascheck.exe  -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               ascheck.obj    -ldbCore -lCom
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include         -o msi.obj -c ../../../src/ioc/dbtemplate/msi.c
g++ -o msi.exe  -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               msi.obj    -lCom -lCom
Installing created executable ../../../bin/cygwin-x86_64/ascheck.exe
Installing created executable ../../../bin/cygwin-x86_64/msi.exe
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl>   -I. -I.. -I../O.Common -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../dbd -o menuConvert.html ../../../src/ioc/bpt/menuConvert.dbd.pod
Installing generated html ../../../html/./menuConvert.html
Installing html ../../../html/./msi.html
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc'>
make -C ca/legacy/pcas/ex install
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex'>
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/makeMakefile.pl> O.cygwin-x86_64 ../../../../../..
mkdir O.Common
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../../.. T_A=cygwin-x86_64 install
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex/O.cygwin-x86_64'>
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exChannel.d -MT exChannel.obj ../../../../../../src/template/base/top/caServerApp/exChannel.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exAsyncPV.d -MT exAsyncPV.obj ../../../../../../src/template/base/top/caServerApp/exAsyncPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exScalarPV.d -MT exScalarPV.obj ../../../../../../src/template/base/top/caServerApp/exScalarPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exVectorPV.d -MT exVectorPV.obj ../../../../../../src/template/base/top/caServerApp/exVectorPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exPV.d -MT exPV.obj ../../../../../../src/template/base/top/caServerApp/exPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF exServer.d -MT exServer.obj ../../../../../../src/template/base/top/caServerApp/exServer.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include          -MM -MF main.d -MT main.obj ../../../../../../src/template/base/top/caServerApp/main.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o main.obj -c ../../../../../../src/template/base/top/caServerApp/main.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exServer.obj -c ../../../../../../src/template/base/top/caServerApp/exServer.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exPV.obj -c ../../../../../../src/template/base/top/caServerApp/exPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exVectorPV.obj -c ../../../../../../src/template/base/top/caServerApp/exVectorPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exScalarPV.obj -c ../../../../../../src/template/base/top/caServerApp/exScalarPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exAsyncPV.obj -c ../../../../../../src/template/base/top/caServerApp/exAsyncPV.cc
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/template/base/top/caServerApp -I../../../../../../include/compiler/gcc -I../../../../../../include/os/cygwin32 -I../../../../../../include         -o exChannel.obj -c ../../../../../../src/template/base/top/caServerApp/exChannel.cc
g++ -o excas.exe  -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               main.obj exServer.obj exPV.obj exVectorPV.obj exScalarPV.obj exAsyncPV.obj exChannel.obj    -lcas -lgdd -lca -lCom
Installing created executable ../../../../../../bin/cygwin-x86_64/excas.exe
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex'>
make -C ca/client/perl install
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl'>
mkdir O.Common
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../.. T_A=cygwin-x86_64 install
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl/O.cygwin-x86_64'>
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl'>
make -C ioc/db/test install
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test'>
mkdir O.Common
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64'>
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbLinkdset.d -MT dbLinkdset.obj ../dbLinkdset.c
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/dbdToRecordtypeH.pl>   -I. -I.. -I../O.Common -I../../../../../dbd -o xRecord.h ../xRecord.dbd
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF xRecord.d -MT xRecord.obj ../xRecord.c
Creating dbd file dbTestIoc.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl>   -I. -I.. -I../O.Common -I../../../../../dbd -o dbTestIoc.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd xRecord.dbd dbLinkdset.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I../../../../../dbd    -o dbTestIoc_registerRecordDeviceDriver.cpp ../O.Common/dbTestIoc.dbd dbTestIoc_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbTestIoc_registerRecordDeviceDriver.d -MT dbTestIoc_registerRecordDeviceDriver.obj dbTestIoc_registerRecordDeviceDriver.cpp
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF recGblCheckDeadbandTest.d -MT recGblCheckDeadbandTest.obj ../recGblCheckDeadbandTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF benchdbConvert.d -MT benchdbConvert.obj ../benchdbConvert.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF arrShorthandTest.d -MT arrShorthandTest.obj ../arrShorthandTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF chfPluginTest.d -MT chfPluginTest.obj ../chfPluginTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbChannelTest.d -MT dbChannelTest.obj ../dbChannelTest.c
Creating dbd file scanIoTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl>   -I. -I.. -I../O.Common -I../../../../../dbd -o scanIoTest.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd yRecord.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I../../../../../dbd -l   -o scanIoTest_registerRecordDeviceDriver.cpp ../O.Common/scanIoTest.dbd scanIoTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF scanIoTest_registerRecordDeviceDriver.d -MT scanIoTest_registerRecordDeviceDriver.obj scanIoTest_registerRecordDeviceDriver.cpp
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/bin/cygwin-x86_64/dbdToRecordtypeH.pl>   -I. -I.. -I../O.Common -I../../../../../dbd -o yRecord.h ../yRecord.dbd
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF scanIoTest.d -MT scanIoTest.obj ../scanIoTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbCaStatsTest.d -MT dbCaStatsTest.obj ../dbCaStatsTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbStateTest.d -MT dbStateTest.obj ../dbStateTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF callbackParallelTest.d -MT callbackParallelTest.obj ../callbackParallelTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF callbackTest.d -MT callbackTest.obj ../callbackTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF testdbConvert.d -MT testdbConvert.obj ../testdbConvert.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbLockTest.d -MT dbLockTest.obj ../dbLockTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbPutLinkTest.d -MT dbPutLinkTest.obj ../dbPutLinkTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include          -MM -MF dbShutdownTest.d -MT dbShutdownTest.obj ../dbShutdownTest.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include         -o xRecord.obj -c ../xRecord.c
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include         -o dbLinkdset.obj -c ../dbLinkdset.c
g++ -o dbTestIoc.dll -shared -Wl,--out-implib,libdbTestIoc.dll.a -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64>       -m64               xRecord.obj dbLinkdset.obj    -ldbCore -lca -lCom   -lpthread    -lm
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include         -o dbShutdownTest.obj -c ../dbShutdownTest.c
g++  -D_POSIX_THREADS -D_POSIX_TIMERS             -DUNIX  -DCYGWIN32     -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include         -o dbTestIoc_registerRecordDeviceDriver.obj -c dbTestIoc_registerRecordDeviceDriver.cpp
g++ -o dbShutdownTest.exe  -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64> -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64>       -m64               dbShutdownTest.obj dbTestIoc_registerRecordDeviceDriver.obj    -ldbTestIoc -ldbCore -lca -lCom
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64/libCom.dll.a(iocsh.obj)>:iocsh.cpp:(.text+0x17f0): multiple definition of `iocshRegister'
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64/libdbTestIoc.dll.a(d002544.o)>:(.text+0x0): first defined here
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64/libCom.dll.a(errlog.obj)>:errlog.c:(.text+0x1430): multiple definition of `eltc'
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64/libdbTestIoc.dll.a(d002269.o)>:(.text+0x0): first defined here
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64/libCom.dll.a(osdThread.obj)>:osdThread.c:(.text+0x1e20): multiple definition of `epicsThreadGetName'
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64/libdbTestIoc.dll.a(d002405.o)>:(.text+0x0): first defined here
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64/libCom.dll.a(osdThread.obj)>:osdThread.c:(.text+0x1e80): multiple definition of `epicsThreadMap'
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64/libdbTestIoc.dll.a(d002423.o)>:(.text+0x0): first defined here
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/lib/cygwin-x86_64/libCom.dll.a(epicsString.obj)>:epicsString.c:(.text+0x7e0): multiple definition of `epicsStrCaseCmp'
/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64/libdbTestIoc.dll.a(d002388.o)>:(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
../../../../../configure/RULES_BUILD:192: recipe for target 'dbShutdownTest.exe' failed
make[3]: *** [dbShutdownTest.exe] Error 1
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64'>
../../../../configure/RULES_ARCHS:56: recipe for target 'install.cygwin-x86_64' failed
make[2]: *** [install.cygwin-x86_64] Error 2
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test'>
../configure/RULES_DIRS:72: recipe for target 'ioc/db/test.install' failed
make[1]: *** [ioc/db/test.install] Error 2
make[1]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src'>
configure/RULES_DIRS:72: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.15-cyg64 #179 APS Jenkins
Build failed in Jenkins: epics-base-3.15-cyg64 #177 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.15-vx69 #137 APS Jenkins
Next: Jenkins build is back to stable : epics-base-3.14-win32 #78 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build failed in Jenkins: epics-base-3.15-cyg64 #177 Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.15-cyg64 #179 APS Jenkins
