2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-cyg64 #25
To: [email protected]
Date: Fri, 5 Jun 2015 16:10:46 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/25/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on cyg64-1 (cyg64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/> returned 0. Command output: "12651 [email protected]
" stderr: ""
[epics-base-3.16-cyg64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.16-cyg64] $ bzr pull --overwrite lp:epics-base/3.16/
No revisions or tags to pull.
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
[epics-base-3.16-cyg64] $ bzr revert
" stderr: ""
[epics-base-3.16-cyg64] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12651 revid:[email protected]
[epics-base-3.16-cyg64] $ sh -xe C:\Users\jenkins\hudson948124523811141135.sh
+ chmod -R +r LICENSE Makefile README configure documentation src startup
+ make
Cannot chdir to /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/tools/>: Permission denied at /usr/lib/perl5/5.14/FindBin.pm line 197
BEGIN failed--compilation aborted at /usr/lib/perl5/5.14/FindBin.pm line 205.
Compilation failed in require at ./src/tools/convertRelease.pl line 23.
BEGIN failed--compilation aborted at ./src/tools/convertRelease.pl line 23.
make -C ./configure install
make[1]: *** configure: Permission denied.  Stop.
configure/RULES_DIRS:88: recipe for target 'configure.install' failed
make: *** [configure.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-cyg64 #26 APS Jenkins
Build failed in Jenkins: epics-base-3.16-cyg64 #24 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-cyg64 #24 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-cyg64 #26 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
