2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win32 #25
To: [email protected]
Date: Mon, 29 Jun 2015 18:54:26 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/25/>
Started by upstream project "epics-base-3.16" build number 26
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/> returned 0. Command output: "12652 [email protected]
" stderr: ""
[epics-base-3.16-win32] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.16-win32] $ bzr pull --overwrite lp:epics-base/3.16
bzr: ERROR: Cannot lock LockDir(file:///C:/jenkins/win32-1/workspace/epics-base-3.16-win32/.bzr/branch/lock): Permission denied: "lock/dwrix1wr61.tmp/info": [Errno 13] Permission denied
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86/*.tap
ERROR: Build step failed with exception
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/> does not exist.
	at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
	at hudson.FilePath.glob(FilePath.java:1740)
	at hudson.FilePath.access$1700(FilePath.java:191)
	at hudson.FilePath$32.invoke(FilePath.java:1718)
	at hudson.FilePath$32.invoke(FilePath.java:1715)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2688)
	at hudson.remoting.UserRequest.perform(UserRequest.java:121)
	at hudson.remoting.UserRequest.perform(UserRequest.java:49)
	at hudson.remoting.Request$2.run(Request.java:325)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	at ......remote call to win32-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1360)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:221)
	at hudson.remoting.Channel.call(Channel.java:753)
	at hudson.FilePath.act(FilePath.java:978)
	at hudson.FilePath.act(FilePath.java:967)
	at hudson.FilePath.list(FilePath.java:1715)
	at hudson.FilePath.list(FilePath.java:1700)
	at hudson.FilePath.list(FilePath.java:1686)
	at org.tap4j.plugin.TapPublisher.locateReports(TapPublisher.java:438)
	at org.tap4j.plugin.TapPublisher.perform(TapPublisher.java:224)
	at hudson.tasks.BuildStepMonitor$2.perform(BuildStepMonitor.java:32)
	at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:761)
	at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:721)
	at hudson.model.Build$BuildExecution.post2(Build.java:183)
	at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:670)
	at hudson.model.Run.execute(Run.java:1766)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:374)
Build step 'Publish TAP Results' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-win32 #26 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32 #24 APS Jenkins
Prev: Re: pCAS username change API Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.16-win32s #25 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.16-win32 #24 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32 #26 APS Jenkins
