2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: STATIC_ASSERT and -Wunused-local-typedefs
Date: Mon, 06 Jul 2015 15:23:17 -0400
FYI, it seems that as of gcc 4.8 there is a new warning which is
triggered by STATIC_ASSERT in Base.
This warning means that the assertion is *not* being violated.
> In file included from /usr/lib/epics/include/epicsEvent.h:13:0,
>                  from /usr/lib/epics/include/epicsThread.h:116,
>                  from ../mrmDataBufTx.cpp:13:
> ../mrmDataBufTx.cpp: In member function 'virtual void mrmDataBufTx::dataSend(epicsUInt32, const epicsUInt8*)':
> /usr/lib/epics/include/epicsAssert.h:50:29: warning: typedef 'static_assert_failed_at_line_100' locally defined but not used [-Wunused-local-typedefs]
>      typedef int STATIC_JOIN(static_assert_failed_at_line_, __LINE__) \
> /usr/lib/epics/include/epicsAssert.h:48:28: note: in definition of macro 'STATIC_JOIN2'
>  #define STATIC_JOIN2(x, y) x ## y
> /usr/lib/epics/include/epicsAssert.h:50:17: note: in expansion of macro 'STATIC_JOIN'
> ../mrmDataBufTx.cpp:100:5: note: in expansion of macro 'STATIC_ASSERT'
>      STATIC_ASSERT(DataTxCtrl_len_max%4==0);
Re: STATIC_ASSERT and -Wunused-local-typedefs Andrew Johnson
Prev: Build failed in Jenkins: epics-base-3.16-win32s #26 APS Jenkins
Next: Re: STATIC_ASSERT and -Wunused-local-typedefs Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pCAS username change API Andrew Johnson
