2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway support for DBE_PROPERTY
To: Ralph Lange <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Fri, 10 Jul 2015 16:10:47 +0000
>> @Murali: Can you continue with your tests as SLAC with a DEV-version Gateway from trunk
I can continue with a dev only version. When you do the next pre release; I will switch to that. Stress testing with the archiver is one of my goals for this and the next month. Thank you so much for helping steer this thru.
Murali
Sent: Friday, July 10, 2015 12:07 AM
To: Shankar, Murali; EPICS Core-Talk
Subject: CA Gateway support for DBE_PROPERTY
All,
I have merged the dbe_props branch [1] (adding full support for the
DBE_PROPERTY event flag) into the CA Gateway trunk, and added running
the tests and showing the results to the CI Jenkins jobs at CloudBees
[2]. (Looks nice!)
Gateway from trunk, or do you want me to push out an official release?
Naturally I would rather have you do some stress testing
(archiverappliance) before I release, but I could also just start the
releasing process so you could test on a -pre1.
There are some minor things (Makefile stuff, clean-up, doc update, a few
more tests) that I would like to include in the next release - no
planned critical changes.
Cheers,
~Ralph
[1]
https://code.launchpad.net/~epics-core/epics-gateway/dbe_props/+merge/262832
[2] https://openepics.ci.cloudbees.com/job/CA_Gateway/
CA Gateway support for DBE_PROPERTY Ralph Lange
Prev: Jenkins build is back to normal : epics-base-3.16-mac-test #6 APS Jenkins
Next: Jenkins build is back to stable : epics-base-3.16 #29 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA Gateway support for DBE_PROPERTY Ralph Lange
Next: Jenkins build is back to stable : epics-base-3.15-win32 #177 APS Jenkins
