2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win32 #28
To: [email protected]
Date: Fri, 10 Jul 2015 14:55:59 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/28/changes>
Changes:
[Andrew Johnson] Merged gen-vcs-version branch
Started by upstream project "epics-base-3.16" build number 29
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/> returned 0. Command output: "12656 [email protected]
" stderr: ""
[epics-base-3.16-win32] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.16-win32] $ bzr pull --overwrite lp:epics-base/3.16
Now on revision 12657.
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
+N  src/template/base/top/exampleApp/Db/_APPNAME_Version.db
+N  src/template/base/top/exampleApp/src/dev_APPNAME_Version.c
+N  src/template/base/top/exampleApp/src/dev_APPNAME_Version.dbd
+N  src/tools/genVersionHeader.pl
 M  configure/CONFIG_BASE
 M  configure/CONFIG_COMMON
 M  configure/RULES_BUILD
 M  documentation/RELEASE_NOTES.html
 M  src/template/base/Makefile
 M  src/template/base/top/exampleApp/Db/Makefile
 M  src/template/base/top/exampleApp/src/Makefile
 M  src/template/base/top/exampleBoot/ioc/st.cmd@Common
 M  src/template/base/top/exampleBoot/ioc/st.cmd@RTEMS
 M  src/template/base/top/exampleBoot/ioc/st.cmd@vxWorks
 M  src/tools/Makefile
All changes applied successfully.
[epics-base-3.16-win32] $ bzr revert
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/> returned 0. Command output: "12657 [email protected]
" stderr: ""
[epics-base-3.16-win32] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12657 revid:[email protected]
[epics-base-3.16-win32] $ cmd /c call C:\Users\jenkins\hudson2009888243325002696.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>make> host
make -C ./configure install.win32-x86
make[1]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure'
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. \
    T_A=win32-x86 install
make[2]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure/O.win32-x86'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure/O.win32-x86'
make[1]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure'
make -C ./src install.win32-x86
make[1]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src'
make -C ./tools install.win32-x86
make[2]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Record.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-win32-x86.pc@ to epics-base-win32-x86.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/win32-x86
"Installing created executable ../../../bin/win32-x86/cvsclean.pl"
"Installing created executable ../../../bin/win32-x86/dos2unix.pl"
"Installing created executable ../../../bin/win32-x86/expandVars.pl"
"Installing created executable ../../../bin/win32-x86/fullPathName.pl"
"Installing created executable ../../../bin/win32-x86/installEpics.pl"
"Installing created executable ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing created executable ../../../bin/win32-x86/makeMakefile.pl"
"Installing created executable ../../../bin/win32-x86/makeTestfile.pl"
"Installing created executable ../../../bin/win32-x86/mkmf.pl"
"Installing created executable ../../../bin/win32-x86/munch.pl"
"Installing created executable ../../../bin/win32-x86/replaceVAR.pl"
"Installing created executable ../../../bin/win32-x86/useManifestTool.pl"
"Installing created executable ../../../bin/win32-x86/genVersionHeader.pl"
"Installing created executable ../../../bin/win32-x86/dbdToMenuH.pl"
"Installing created executable ../../../bin/win32-x86/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/win32-x86/dbdExpand.pl"
"Installing created executable ../../../bin/win32-x86/dbExpand.pl"
"Installing created executable ../../../bin/win32-x86/dbdToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podRemove.pl"
"Installing created executable ../../../bin/win32-x86/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't open ../O.Common/EPICS/: No such file or directory.
"Installing generated html ../../../html/./EPICS/Getopts.html"
installEpics.pl: No such file '../O.Common/EPICS/Getopts.html' at ../../../src/tools/installEpics.pl line 53.
mkdir ../../../html/./EPICS
../../../configure/RULES_BUILD:473: recipe for target '../../../html/./EPICS/Getopts.html' failed
make[3]: *** [../../../html/./EPICS/Getopts.html] Error 2
make[3]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools/O.win32-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools'
../configure/RULES_DIRS:88: recipe for target 'tools.install.win32-x86' failed
make[1]: *** [tools.install.win32-x86] Error 2
make[1]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src'
configure/RULES_DIRS:88: recipe for target 'src.install.win32-x86' failed
make: *** [src.install.win32-x86] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-win32 #29 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32 #27 APS Jenkins
Prev: Jenkins build is back to stable : epics-base-3.16 #29 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win64 #24 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.16-win32 #27 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32 #29 APS Jenkins
