2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win64s #27
To: [email protected]
Date: Fri, 24 Jul 2015 12:55:04 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/27/>
Started by upstream project "epics-base-3.16-win64" build number 27
originally caused by:
 Started by upstream project "epics-base-3.16" build number 32
  Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>
[epics-base-3.16-win64] $ cmd /c call C:\Users\jenkins\hudson1751419532391640136.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static host
make -C ./configure install.windows-x64-static
make[1]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64-static ../..
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
make[2]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64-static'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64-static'
make[1]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure'
make -C ./src install.windows-x64-static
make[1]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src'
make -C ./tools install.windows-x64-static
make[2]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools'
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64-static'
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-windows-x64-static.pc"
mkdir ../../../bin/windows-x64-static
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't open ../O.Common/EPICS/: No such file or directory.
installEpics.pl: No such file '../O.Common/EPICS/Getopts.html' at ../../../src/tools/installEpics.pl line 53.
../../../configure/RULES_BUILD:473: recipe for target '../../../html/./EPICS/Getopts.html' failed
make[3]: *** [../../../html/./EPICS/Getopts.html] Error 2
make[3]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64-static'
../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64-static' failed
make[2]: *** [install.windows-x64-static] Error 2
make[2]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools'
../configure/RULES_DIRS:88: recipe for target 'tools.install.windows-x64-static' failed
make[1]: *** [tools.install.windows-x64-static] Error 2
make[1]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src'
configure/RULES_DIRS:88: recipe for target 'src.install.windows-x64-static' failed
make: *** [src.install.windows-x64-static] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is unstable: epics-base-3.16-win64s #28 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win64s #26 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32 #31 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32s #31 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.16-win64s #26 APS Jenkins
Next: Jenkins build is unstable: epics-base-3.16-win64s #28 APS Jenkins
