2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base R3.15.3-rc1 available
To: <[email protected]>
Date: Thu, 5 Nov 2015 16:53:30 +0100
Hi Andrew
thanks for your answer.
On 11/03/2015 05:44 PM, Andrew Johnson wrote:
> On 11/03/2015 08:30 AM, Benjamin Franksen wrote:
>> There is one small problem in the build system (probably in all
>> 3.15 versions) and it concerns dependency generation when a
>> generated header file is included. This can cause error messages
>> from gcc when using parallel make, such as
>>> ../builtin.c:11:17: fatal error: snl.h: No such file or
>>> directory #include "snl.h"
>>> compilation terminated.
>> The solution is to add -MG to the compiler flags when generating
>> dependencies (see the attached patch). According to the gcc man
>> page, "-MG assumes missing header files are generated files and
>> adds them to the dependency list without raising an error."
> Your -MG solution assumes that we only use gcc to build Base, which is
> not true for some targets, and it doesn't always result in the correct
> dependency information being output.
Right, forgot about the other compilers. (Apparently they all support
-MM -MF, I wouldn't have expected that.)
> The correct solution is to make snl.h an explicit dependency of the
> builtin$(DEP) and any similar targets in your Makefile, for example:
> include $(TOP)/configure/RULES
> ifdef BASE_3_15
>   builtin$(DEP): $(COMMON_DIR)/snl.h
> endif
Yes, more or less. I would rather avoid having to maintain these
dependencies manually, though. I mean, that's the reason we generate the
.d files in the first place.
Anyway, as it turns out, an order dependency suffices in my case, since
the generated snl.h itself never includes anything, so the *.d files
never need to be rebuilt when it changes. And since it's just an order
dependency, it doesn't hurt to declare it for _all_ *.d files:
  $(HDEPENDS_FILES): | snl.h
If I haven't overlooked something subtle this should nicely solve the
problem.
> Are you trying to fix Peter Heesterman's sequencer build problem? The
> -MG flag wouldn't help him anyway since he's building on Windows, but
> the above $(DEP): fix should.
No, this is just something that bothered me for a while. The error
messages are harmless as I stated in another message, but still annoying.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS Base R3.15.3-rc1 available Andrew Johnson
EPICS Base R3.15.3-rc1 available Ralph Lange
Re: EPICS Base R3.15.3-rc1 available Benjamin Franksen
Prev: Re: EPICS Base R3.15.3-rc1 available Andrew Johnson
Next: Re: EPICS Base R3.15.3-rc1 available Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
