2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Autosave called epicsMessageQueueSend with opMsgQueue==NULL
To: "Mooney, Tim M." <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Thu, 28 Jan 2016 11:43:00 -0200
 Tim, I'm sending you the pull request in another e-mail.
2016-01-27 19:09 GMT-02:00 Henrique Almeida <[email protected]>:
Just create the queue before starting the thread. That would be the usual pattern.
Em 27/01/2016 19:06, "Mooney, Tim M." <[email protected]> escreveu:
Hi Henrique,
Thanks for this.  It looks like fdbrestore() is using the message queue before the save_restore task has created it.  request_manual_restore() should defend itself against this, but that wouldn't solve the problem of allowing code to call it before it can be called successfully.  I should fix this so any code that starts the save_restore task waits until the task is fully functional before returning.
A workaround for now would be to call epicsThreadSleep(1.) between create_triggered_set() (which starts the save_restore task if it's not already started) and fdbrestore().
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Henrique Almeida [[email protected]]
Sent: Wednesday, January 27, 2016 2:18 PM
To: EPICS Core-Talk
Subject: Autosave called epicsMessageQueueSend with opMsgQueue==NULL
 Hello, I'm testing an IOC that uses autosave-5-6-1 from synApps 5.8 and I'm seeing a large amount of crashes during IOC boot. Spreading debug messages through EPICS code showed that autosave was calling the function epicsMessageQueueSend() with a null message queue object, for example:
makeAutosaveFileFromDbInfo("/usr/local/epics/apps/config/SOL1/autosave/parker_positions1.req", "autosaveFields_pass0")
dbpf SOL1:PARKER1:m1.SSET 1
DBR_SHORT:          1         0x1
create_triggered_set("parker_positions1.req", SOL1:PARKER1:autosave.VAL, "")
fdbrestore("parker_positions1.sav")
save_restore:fdbrestore:entry
../save_restore.c:request_manual_restore:2678 Called epicsMessageQueueSend with opMsgQueue=NULL
pmg=NULL
save_restore:806
Falha de segmentação (imagem do núcleo gravada)
Core dump backtrace shows the same problem:
(gdb) bt
#0  0x001e454f in mySend (pmsg=0x0, message=0xbfb95e2c, size=500, timeout=-1)
    at ../../../src/libCom/osi/os/default/osdMessageQueue.cpp:161
#1  0x00768cd0 in request_manual_restore (filename=0x836ea3b "parker_positions1.sav",
    file_type=1, macrostring=0x0, callbackFunction=0x7663c0 <defaultCallback>, puserPvt=0x0)
    at ../save_restore.c:2680
#2  0x00768e5b in fdbrestore (filename=0x836ea3b "parker_positions1.sav")
    at ../save_restore.c:2639
#3  0x00768e8f in fdbrestore_CallFunc (args=0x83080c0) at ../save_restore.c:3566
#4  0x001cfcb1 in iocshBody (pathname=<value optimized out>, commandLine=0x0, macros=0x0)
    at ../../../src/libCom/iocsh/iocsh.cpp:813
#5  0x001d0475 in iocsh (pathname=0xbfb96729 "./parker_st1.cmd")
    at ../../../src/libCom/iocsh/iocsh.cpp:881
#6  0x0804e33d in main (argc=2, argv=0xbfb96264) at ../motorPXIMain.cpp:17
Can anybody confirm this problem ? Here is the relevant st.cmd snippet:
set_requestfile_path("${MOTORHYPPIE_AUTOSAVE}", "")
set_savefile_path("${MOTORHYPPIE_AUTOSAVE}", "")
set_pass0_restoreFile("parker_positions1.sav")
save_restoreSet_NumSeqFiles(0)
save_restoreSet_DatedBackupFiles(0)
pxiCreateSM("motor","COM3PARKER1Motor1")
motorHyppieSetup(10, 1)
motorHyppieConfig(0,"COM3PARKER1Motor1")
dbLoadTemplate ("/usr/local/epics/apps/config/${EPICS_HOSTNAME}/parker_motor1.substitutions")
cd ${TOP}/iocBoot/${IOC}
iocInit
makeAutosaveFileFromDbInfo("${MOTORHYPPIE_AUTOSAVE}/parker_positions1.req", "autosaveFields_pass0")
dbpf SOL1:PARKER1:m1.SUSE 1
Autosave called epicsMessageQueueSend with opMsgQueue==NULL Henrique Almeida
RE: Autosave called epicsMessageQueueSend with opMsgQueue==NULL Mooney, Tim M.
RE: Autosave called epicsMessageQueueSend with opMsgQueue==NULL Henrique Almeida
Prev: RE: Autosave called epicsMessageQueueSend with opMsgQueue==NULL Henrique Almeida
Next: [PATCH RFC] Fix race when creating opMsgQueue Henrique Dante de Almeida
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Jan 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
