2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.16-win64 #52
To: <[email protected]>
Date: Tue, 9 Feb 2016 14:00:39 -0600
On 02/08/2016 07:01 PM, APS Jenkins wrote:
> cl                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../.
>  /src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include         -c ../../../src/libCom/dbmf/dbmf.c
> dbmf.c
> ..\valgrind/valgrind.h(454) : fatal error C1189: #error :  Unsupported compiler.
> ../../../configure/RULES_BUILD:220: recipe for target 'dbmf.obj' failed
Extending the architecture tests in the valgrind.h file to also require
__GNUC__ to be defined just moves the 64-bit compile failures from here
to the same place as in the 32-bit builds...
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
Build failed in Jenkins: epics-base-3.16-win64 #52 APS Jenkins
Prev: Re: Jenkins build became unstable: epics-base-3.16 #57 Andrew Johnson
Next: Re: Build failed in Jenkins: epics-base-3.16-win32 #56 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.16-win64 #52 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-win64 #53 APS Jenkins
ANJ, 09 Feb 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
