2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13
To: [email protected]
Date: Mon, 15 Feb 2016 18:33:08 -0500
On 02/12/2016 12:33 PM, Andrew Johnson wrote:
> Hi Michael,
> On 02/12/2016 11:06 AM, APS Jenkins wrote:
>> src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
>> src/std/rec/test/O.linux-x86/asTest.tap .................. ok
>> Bailout called.  Further testing stopped:  testMonitorWait() exceeds timeout
>> FAILED--Further testing stopped: testMonitorWait() exceeds timeout
> My fix was just to re-run the tests; given that this failure has
> happened before on a different architecture, I think the 10 second
> timeout delay in testMonitorWait() is just too short for a busy build
> slave. Since the effect of failure is to kill all further testing I have
> bumped it all the way up to 60 seconds.
It's happened again.  From the .tap log the timeout is a symptom of a
previous failure.  I'm guessing this was the case previously.
> 1..10
> ## EPICS R3.16.0-DEV $$Date$$
> ## EPICS Base built Feb 15 2016
> ok  1 - dbGetField("rec:ai", 8) -> 0.000000e+00 == 0.000000e+00
> ok  2 - dbGetField("rec:ai.INP", 0) -> "0" == "0"
> not ok  3 - dbPutField(rec:link1.PROC, 5, ...) == -1
> Bail out! testMonitorWait() exceeded 60 second timeout
I haven't yet been able to replicate this locally.
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
Build failed in Jenkins: epics-base-3.16-linux32-test #13 APS Jenkins
Prev: Jenkins build became unstable: epics-base-3.16 #63 APS Jenkins
Next: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
ANJ, 15 Feb 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
