2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-linux32-test #24
To: [email protected]
Date: Fri, 26 Feb 2016 14:42:35 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32-test/24/>
[...truncated 270 lines...]
not ok 858 - channel_report: level correct
not ok 860 - channel_report: level correct
not ok 908 - channel_report: level correct
not ok 910 - channel_report: level correct
not ok 958 - channel_report: level correct
not ok 960 - channel_report: level correct
not ok 1017 - channel_report: level correct
not ok 1019 - channel_report: level correct
not ok 1076 - channel_report: level correct
not ok 1078 - channel_report: level correct
not ok 1135 - channel_report: level correct
not ok 1137 - channel_report: level correct
not ok 1194 - channel_report: level correct
not ok 1196 - channel_report: level correct
not ok 1243 - channel_report: level correct
not ok 1245 - channel_report: level correct
not ok 1297 - channel_report: level correct
not ok 1299 - channel_report: level correct
not ok 1357 - channel_report: level correct
not ok 1359 - channel_report: level correct
not ok 1422 - channel_report: level correct
not ok 1424 - channel_report: level correct
Failed 29/1433 subtests
src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbChArrTest.tap .............. ok
src/ioc/db/test/O.linux-x86/dbChannelTest.tap ............
Failed 1/76 subtests
src/ioc/db/test/O.linux-x86/dbLockTest.tap ............... ok
src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbShutdownTest.tap ........... ok
src/ioc/db/test/O.linux-x86/dbStateTest.tap .............. ok
src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap .. ok
src/ioc/db/test/O.linux-x86/scanIoTest.tap ............... ok
src/ioc/db/test/O.linux-x86/testdbConvert.tap ............ ok
src/ioc/dbtemplate/test/O.linux-x86/msi.tap .............. ok
src/libCom/test/O.linux-x86/blockingSockTest.tap ......... ok
src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap ....... ok
src/libCom/test/O.linux-x86/epicsAtomicTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsCalcTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsEllTest.tap ............. ok
src/libCom/test/O.linux-x86/epicsEnvTest.tap ............. ok
src/libCom/test/O.linux-x86/epicsErrlogTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsEventTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsExceptionTest.tap ....... ok
src/libCom/test/O.linux-x86/epicsExitTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsInlineTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsMMIOTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsMathTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap .... ok
src/libCom/test/O.linux-x86/epicsMutexTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsSockResolveTest.tap ..... ok
src/libCom/test/O.linux-x86/epicsSpinTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsStackTraceTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsStdioTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsStdlibTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsStringTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap ..... ok
src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap .. ok
src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap ... ok
src/libCom/test/O.linux-x86/epicsThreadTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsTimeTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap ........ ok
src/libCom/test/O.linux-x86/epicsTimerTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsTypesTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsUnitTestTest.tap ........ ok
src/libCom/test/O.linux-x86/macDefExpandTest.tap ......... ok
src/libCom/test/O.linux-x86/macLibTest.tap ............... ok
src/libCom/test/O.linux-x86/ringBytesTest.tap ............ ok
src/libCom/test/O.linux-x86/ringPointerTest.tap .......... ok
src/libCom/test/O.linux-x86/taskwdTest.tap ............... ok
src/std/filters/test/O.linux-x86/arrTest.tap ............. ok
src/std/filters/test/O.linux-x86/dbndTest.tap ............ ok
src/std/filters/test/O.linux-x86/syncTest.tap ............ ok
src/std/filters/test/O.linux-x86/tsTest.tap .............. ok
src/std/rec/test/O.linux-x86/analogMonitorTest.tap ....... ok
src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
src/tools/test/O.linux-x86/Breaktable.tap ................ ok
src/tools/test/O.linux-x86/DBD.tap ....................... ok
src/tools/test/O.linux-x86/Device.tap .................... ok
src/tools/test/O.linux-x86/Driver.tap .................... ok
src/tools/test/O.linux-x86/Function.tap .................. ok
src/tools/test/O.linux-x86/Menu.tap ...................... ok
src/tools/test/O.linux-x86/Recfield.tap .................. ok
src/tools/test/O.linux-x86/Recordtype.tap ................ ok
src/tools/test/O.linux-x86/Registrar.tap ................. ok
src/tools/test/O.linux-x86/Snippets.tap .................. ok
src/tools/test/O.linux-x86/Variable.tap .................. ok
src/tools/test/O.linux-x86/macLib.tap .................... ok
Test Summary Report
src/ioc/db/test/O.linux-x86/chfPluginTest.tap          (Wstat: 0 Tests: 1433 Failed: 29)
  Failed tests:  629, 658, 696, 740, 742, 790, 792, 858
                860, 908, 910, 958, 960, 1017, 1019, 1076
                1078, 1135, 1137, 1194, 1196, 1243, 1245
                1297, 1299, 1357, 1359, 1422, 1424
src/ioc/db/test/O.linux-x86/dbChannelTest.tap          (Wstat: 0 Tests: 75 Failed: 0)
  Parse errors: Bad plan.  You planned 76 tests but ran 75.
Files=70, Tests=9140,  5 wallclock secs ( 4.13 usr  0.38 sys +  0.02 cusr  0.17 csys =  4.70 CPU)
Result: FAIL
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/arrShorthandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/arrShorthandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/callbackParallelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/callbackParallelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/chfPluginTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/chfPluginTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbChArrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbChArrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbChannelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbChannelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbLockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbLockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbShutdownTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbShutdownTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbStateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/dbStateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/scanIoTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/scanIoTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/testdbConvert.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/db/test/O.linux-x86/testdbConvert.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86/msi.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86/msi.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsAtomicTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsAtomicTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsExceptionTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsExceptionTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsInlineTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsInlineTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMMIOTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMMIOTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsSpinTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsSpinTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStackTraceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStackTraceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStdlibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStdlibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTypesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsTypesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/macDefExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/macDefExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/libCom/test/O.linux-x86/taskwdTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/arrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/arrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/dbndTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/dbndTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/syncTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/syncTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/tsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/filters/test/O.linux-x86/tsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/rec/test/O.linux-x86/analogMonitorTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/rec/test/O.linux-x86/analogMonitorTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/rec/test/O.linux-x86/arrayOpTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/std/rec/test/O.linux-x86/arrayOpTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Breaktable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Breaktable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/DBD.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/DBD.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Device.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Device.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Driver.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Driver.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Function.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Function.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Menu.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Menu.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Recfield.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Recfield.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Recordtype.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Recordtype.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Registrar.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Registrar.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Snippets.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Snippets.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Variable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/Variable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/macLib.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-linux32-test/builds/24/tap-master-files/src/tools/test/O.linux-x86/macLib.tap].
Not all test cases were executed according to the test set plan. Marking build as UNSTABLE
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.15-linux32-test #25 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15-mac-test #40 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win32-test #29 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-mac-test #41 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-linux32-test #25 APS Jenkins
ANJ, 26 Feb 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
