2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strict aliasing blog-post
Cc: EPICS core-talk <[email protected]>
Date: Wed, 16 Mar 2016 07:56:41 +0100
In general, yes.
But: This is really compiler dependent.
A better approach would be to go through the code base, and rework the problematic code,
step by step.
And when this is done, have a look if there are „volatile“ missing,
and/or if we need better support for multi-core, like synchronizing the L2 caches
on some ARM platforms.
(But I’m not sure, if anybody is running EPICS on this kind of hardware)
It may be good enough to enable it for gcc, if version >= 5.
And what about clang ?
/Torsten
Am 15.03.2016 um 19:08 schrieb Andrew Johnson <[email protected]>:
> http://blog.regehr.org/archives/1307
> Should we add the -fno-strict-aliasing flag to the EPICS build rules?
> - Andrew
Re: Strict aliasing blog-post Johnson, Andrew N.
Re: Strict aliasing blog-post Michael Davidsaver
Strict aliasing blog-post Andrew Johnson
Prev: Strict aliasing blog-post Andrew Johnson
Next: Re: Strict aliasing blog-post Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Mar 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
