2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Merge conflict in base-3.16
To: EPICS Core-Talk <[email protected]>
Date: Wed, 7 Sep 2016 09:52:01 +0200
On 07/09/2016 01:31, Michael Davidsaver wrote:
On 09/06/2016 07:04 PM, Andrew Johnson wrote:
While merging the 3.15 changes into 3.16 I discovered these conflicting
changes. Which one is correct, and if it's the 3.16 change, should it be
back-ported to 3.15?
I think yours, though it may not make a difference practically.  If
copyInHeader() only fails in allocRawMsg() fails, in which case I think
no new message is ready to be sent.  In this case I would think that
commitMsg() is either a no-op, or an error.  I haven't look far enough
to tell which is the case.
+1
My fix was only to suppress the "variable set but not used" warning, and not setting it was the easy fix without behavior change.
Cheers,
~Ralph
Re: Merge conflict in base-3.16 Andrew Johnson
Re: Merge conflict in base-3.16 Michael Davidsaver
Prev: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Next: Re: Merge conflict in base-3.16 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Merge conflict in base-3.16 Michael Davidsaver
ANJ, 07 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
