2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS 3.15.4 on RTEMS rtems-4.11.99.0 (PowerPC/Generic (classic FPU)/beatnik)
Date: Tue, 13 Sep 2016 17:15:54 +0200
I just finished tests to the EPICS port to RTEMS 4.12 on a ppc CPU (beatnik, MVME6100).
The libComTestHarness.boot runs successful:
    EPICS Test Harness Results
All tests successful.
Programs=34, Tests=2839, 305 wallclock secs
***** epicsExitTest *****
1..15
ok  1 - Registered counter()
Programs=34, Tests=2839, 309 wallclock secs
ok  2 - counter() called once
ok  3 - unregistered counter() not called
ok  4 - Registered mainExit()
# threadA starting
ok  5 - Registered atExit(0x1475eb0)
ok  6 - Registered atThreadExit(0x1475eb0)
# threadA waiting for atExit
# threadB starting
ok  7 - Registered atExit(0x1475f00)
ok  8 - Registered atThreadExit(0x1475f00)
# threadB waiting for atExit
# Calling epicsExit
ok  9 - threadB reached atExit
ok 10 - threadB terminating
ok 11 - threadB destroying pinfo
ok 12 - threadA reached atExit
ok 13 - threadA terminating
ok 14 - threadA destroying pinfo
ok 15 - Reached mainExit
    Results
       Tests: 15
      Passed:  15 = 100.00%
Now I will make the changes “chic” and will push them back to bazaar. Hope it can be used with
other architectures too.
Still to do: booting with settings from NVRAM, I just implemented the bootp/dhcp booting.
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Build problem in pvData with VS 2015 Mark Rivers
Prev: Build problem in pvData with VS 2015 Mark Rivers
Next: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Time issues on Linux Ralph Lange
ANJ, 27 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
