2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Time issues on Linux
To: <[email protected]>
Date: Tue, 27 Sep 2016 11:06:40 -0500
Hi Ralph,
I thought that's what was probably causing your issue.
On 09/27/2016 08:28 AM, Ralph Lange wrote:
> In libCom/osi's epicsTime module, I see epicsTimeToTM() and
> epicsTimeToGMTM() methods that allow to select if the timezone mechanism
> should be used or not.
> However, the other direction only offers epicsTimeFromTM() that honors
> timezones, and eventually calls mktime().
> Would you agree that epicsTimeFromGMTM() and the matching
> epicsTime::epicsTime(const gm_tm_nano_sec &tm) should be added?
Yes, with our own implementation in epicsTime.cpp. I would suggest
stealing the algorithm for timegm() from
ftp://ftp.netbsd.org/pub/pkgsrc/current/pkgsrc/pkgtools/libnbcompat/files/timegm.c
without explicitly copying their code (ours is going to be different
anyway given that it's producing an epicsTime).
As this change will only be adding new methods/routines I'd be happy to
take it on the 3.14 branch (hopefully in time for the 3.14.12.6 release
at the end of October).
This routine could be useful in epicsTimeTest, IIRC there are some
things we don't test because of the effect of the time-zone on results.
- Andrew
Time issues on Linux Ralph Lange
Prev: Jenkins build is back to stable : epics-base-3.14 #199 APS Jenkins
Next: EPICS 3.15.5 planning Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Time issues on Linux Ralph Lange
Next: RE: Problem in 3.14.12.5 with osd/WIN32/osdTime.h with latest version of MinGW Mark Rivers
ANJ, 03 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
