2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Wonder about the processing speed
To: 장진수 <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Nov 2016 01:29:14 +0000
PP and NPP don't really have to do with processing speed, they have to do with functionality.
PP means that when the link is read or written it will process the record being linked to.  NPP simply writes or reads the value without processing the record being linked to.  Whether to use PP or NPP depends on whether you need to linked record to process or not.  Speed it not an issue: if you need the record to process use PP, if you don't use NPP.
From: [email protected] [[email protected]] on behalf of 장진수 [[email protected]]
Sent: Sunday, November 06, 2016 7:13 PM
To: [email protected]
Subject: Wonder about the processing speed
Hello core-talk~
Thank you for comment me before, about connecting IOC and CSS.
As you linked me to a teck-talk i can solve it the problem.
Im a univ student for interesting EPICS.
I succeed to build a IOC and CSS and connect it in a local ip enviorment.
But as i studying vdct, I have a question.
When i make records only using PP or NPP, which is more fast about processing speed?
[https://mail.naver.com/readReceipt/notify/?img=Ww%2BoWN3qWHbsFAKZKBF8hAp0M4MwKoiCFruXK6iCaxUwaAtlK4E9aAI0K6MqF43gMr9TM40npB%2B0Mog974lR74lcWNFlbX30WLloWrdQadFTb4ER%2BzJn1dICbHK5M6ln74%2BT%2B2%3D%3D.gif]
Wonder about the processing speed 장진수
Prev: Wonder about the processing speed 장진수
Next: AppDevGuide updates Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 10 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
