2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-sol #83
To: [email protected]
Date: Wed, 7 Dec 2016 15:34:54 -0600 (CST)
https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/83/------------------------------------------
Started by upstream project "epics-base-3.14" build number 221
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on sol-hera (sol-sparc) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/> returned 0. Command output: "12686 [email protected]
" stderr: ""
[epics-base-3.14-sol] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.14-sol] $ bzr pull --overwrite bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.14/
ssh: connect to host bazaar.launchpad.net port 22: Connection timed out
bzr: ERROR: Connection closed: Unexpected end of message. Please check connectivity and permissions, and report a bug if problems persist.
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.solaris-sparc/*.tap
ERROR: Build step failed with exception
<https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/> does not exist.
	at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
	at hudson.FilePath.glob(FilePath.java:1741)
	at hudson.FilePath.access$1700(FilePath.java:190)
	at hudson.FilePath$32.invoke(FilePath.java:1719)
	at hudson.FilePath$32.invoke(FilePath.java:1716)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2719)
	at hudson.remoting.UserRequest.perform(UserRequest.java:120)
	at hudson.remoting.UserRequest.perform(UserRequest.java:48)
	at hudson.remoting.Request$2.run(Request.java:332)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
	at ......remote call to sol-hera(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1416)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:220)
	at hudson.remoting.Channel.call(Channel.java:781)
	at hudson.FilePath.act(FilePath.java:979)
	at hudson.FilePath.act(FilePath.java:968)
	at hudson.FilePath.list(FilePath.java:1716)
	at hudson.FilePath.list(FilePath.java:1701)
	at hudson.FilePath.list(FilePath.java:1687)
	at org.tap4j.plugin.TapPublisher.locateReports(TapPublisher.java:647)
	at org.tap4j.plugin.TapPublisher.performImpl(TapPublisher.java:383)
	at org.tap4j.plugin.TapPublisher.perform(TapPublisher.java:371)
	at hudson.tasks.BuildStepCompatibilityLayer.perform(BuildStepCompatibilityLayer.java:78)
	at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
	at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:782)
	at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:723)
	at hudson.model.Build$BuildExecution.post2(Build.java:185)
	at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:668)
	at hudson.model.Run.execute(Run.java:1763)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:410)
Build step 'Publish TAP Results' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14-sol #84 APS Jenkins
Prev: Re: CII Best Practices Badge Status Andrew Johnson
Next: Jenkins build is back to normal : epics-base-3.14-sol #84 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
