2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14 #222
To: [email protected]
Date: Thu, 8 Dec 2016 15:14:18 -0600 (CST)
https://jenkins.aps.anl.gov/job/epics-base-3.14/222/Changes:
[Andrew Johnson] asLib message buffer too small (Freddie Akeroyd)
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14/ws/> returned 0. Command output: "12687 [email protected]
" stderr: ""
[workspace] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[workspace] $ bzr pull --overwrite bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.14/
 M  src/as/asLib_lex.l
All changes applied successfully.
Now on revision 12688.
[workspace] $ bzr revert
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14/ws/> returned 0. Command output: "12688 [email protected]
" stderr: ""
[workspace] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12688 revid:[email protected]
[workspace] $ /bin/sh -xe /tmp/hudson7798225793294392537.sh
+ make -O -j4 linux-x86_64
make: invalid option -- 'O'
Usage: make [options] [target] ...
Options:
  -b, -m                      Ignored for compatibility.
  -B, --always-make           Unconditionally make all targets.
  -C DIRECTORY, --directory=DIRECTORY
                              Change to DIRECTORY before doing anything.
  -d                          Print lots of debugging information.
  --debug[=FLAGS]             Print various types of debugging information.
  -e, --environment-overrides
                              Environment variables override makefiles.
  -f FILE, --file=FILE, --makefile=FILE
                              Read FILE as a makefile.
  -h, --help                  Print this message and exit.
  -i, --ignore-errors         Ignore errors from commands.
  -I DIRECTORY, --include-dir=DIRECTORY
                              Search DIRECTORY for included makefiles.
  -j [N], --jobs[=N]          Allow N jobs at once; infinite jobs with no arg.
  -k, --keep-going            Keep going when some targets can't be made.
  -l [N], --load-average[=N], --max-load[=N]
                              Don't start multiple jobs unless load is below N.
  -L, --check-symlink-times   Use the latest mtime between symlinks and target.
  -n, --just-print, --dry-run, --recon
                              Don't actually run any commands; just print them.
  -o FILE, --old-file=FILE, --assume-old=FILE
                              Consider FILE to be very old and don't remake it.
  -p, --print-data-base       Print make's internal database.
  -q, --question              Run no commands; exit status says if up to date.
  -r, --no-builtin-rules      Disable the built-in implicit rules.
  -R, --no-builtin-variables  Disable the built-in variable settings.
  -s, --silent, --quiet       Don't echo commands.
  -S, --no-keep-going, --stop
                              Turns off -k.
  -t, --touch                 Touch targets instead of remaking them.
  -v, --version               Print the version number of make and exit.
  -w, --print-directory       Print the current directory.
  --no-print-directory        Turn off -w, even if it was turned on implicitly.
  -W FILE, --what-if=FILE, --new-file=FILE, --assume-new=FILE
                              Consider FILE to be infinitely new.
  --warn-undefined-variables  Warn when an undefined variable is referenced.
This program built for x86_64-redhat-linux-gnu
Report bugs to <[email protected]>
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86_64/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14 #223 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.15-linux32 #264 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-vx55 #173 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Jenkins build is back to normal : epics-base-3.14 #223 APS Jenkins
ANJ, 08 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
