2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-linux32-test #43
To: [email protected]
Date: Mon, 30 Jan 2017 18:26:40 -0600 (CST)
https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/43/------------------------------------------
[...truncated 253 lines...]
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test/O.linux-x86'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src/std/rec/test'>
make: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.16-linux32-test/ws/src'>
+ prove --failures --recurse --ext .tap --exec cat src
src/ioc/db/test/O.linux-x86/arrShorthandTest.tap ......... ok
src/ioc/db/test/O.linux-x86/callbackParallelTest.tap ..... ok
src/ioc/db/test/O.linux-x86/callbackTest.tap ............. ok
src/ioc/db/test/O.linux-x86/chfPluginTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbCaLinkTest.tap .............
not ok  7 - temp (0) == 42 (42)
Failed 1/99 subtests
src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbChArrTest.tap .............. ok
src/ioc/db/test/O.linux-x86/dbChannelTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbLockTest.tap ............... ok
src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap ............ ok
src/ioc/db/test/O.linux-x86/dbScanTest.tap ............... ok
src/ioc/db/test/O.linux-x86/dbShutdownTest.tap ........... ok
src/ioc/db/test/O.linux-x86/dbStateTest.tap .............. ok
src/ioc/db/test/O.linux-x86/dbStressTest.tap ............. ok
src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap .. ok
src/ioc/db/test/O.linux-x86/scanIoTest.tap ............... ok
src/ioc/db/test/O.linux-x86/testdbConvert.tap ............ ok
src/ioc/dbtemplate/test/O.linux-x86/msi.tap .............. ok
src/libCom/test/O.linux-x86/blockingSockTest.tap ......... ok
src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap ....... ok
src/libCom/test/O.linux-x86/epicsAtomicTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsCalcTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsEllTest.tap ............. ok
src/libCom/test/O.linux-x86/epicsEnvTest.tap ............. ok
src/libCom/test/O.linux-x86/epicsErrlogTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsEventTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsExitTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsInlineTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsMMIOTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsMathTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap .... ok
src/libCom/test/O.linux-x86/epicsMutexTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsSockResolveTest.tap ..... ok
src/libCom/test/O.linux-x86/epicsSpinTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsStackTraceTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsStdioTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsStdlibTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsStringTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap ..... ok
src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap ...... ok
src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap .. ok
src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap ... ok
src/libCom/test/O.linux-x86/epicsThreadTest.tap .......... ok
src/libCom/test/O.linux-x86/epicsTimeTest.tap ............ ok
src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap ........ ok
src/libCom/test/O.linux-x86/epicsTimerTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsTypesTest.tap ........... ok
src/libCom/test/O.linux-x86/epicsUnitTestTest.tap ........ ok
src/libCom/test/O.linux-x86/macDefExpandTest.tap ......... ok
src/libCom/test/O.linux-x86/macLibTest.tap ............... ok
src/libCom/test/O.linux-x86/ringBytesTest.tap ............ ok
src/libCom/test/O.linux-x86/ringPointerTest.tap .......... ok
src/libCom/test/O.linux-x86/taskwdTest.tap ............... ok
src/std/filters/test/O.linux-x86/arrTest.tap ............. ok
src/std/filters/test/O.linux-x86/dbndTest.tap ............ ok
src/std/filters/test/O.linux-x86/syncTest.tap ............ ok
src/std/filters/test/O.linux-x86/tsTest.tap .............. ok
src/std/rec/test/O.linux-x86/analogMonitorTest.tap ....... ok
src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
src/std/rec/test/O.linux-x86/asTest.tap .................. ok
src/std/rec/test/O.linux-x86/compressTest.tap ............ ok
src/std/rec/test/O.linux-x86/linkRetargetLinkTest.tap .... ok
src/std/rec/test/O.linux-x86/regressTest.tap ............. ok
src/tools/test/O.linux-x86/Breaktable.tap ................ ok
src/tools/test/O.linux-x86/DBD.tap ....................... ok
src/tools/test/O.linux-x86/Device.tap .................... ok
src/tools/test/O.linux-x86/Driver.tap .................... ok
src/tools/test/O.linux-x86/Function.tap .................. ok
src/tools/test/O.linux-x86/Menu.tap ...................... ok
src/tools/test/O.linux-x86/Recfield.tap .................. ok
src/tools/test/O.linux-x86/Recordtype.tap ................ ok
src/tools/test/O.linux-x86/Registrar.tap ................. ok
src/tools/test/O.linux-x86/Snippets.tap .................. ok
src/tools/test/O.linux-x86/Variable.tap .................. ok
src/tools/test/O.linux-x86/macLib.tap .................... ok
Test Summary Report
src/ioc/db/test/O.linux-x86/dbCaLinkTest.tap           (Wstat: 0 Tests: 99 Failed: 1)
  Failed test:  7
Files=76, Tests=9202,  5 wallclock secs ( 3.95 usr  0.52 sys +  0.04 cusr  0.17 csys =  4.68 CPU)
Result: FAIL
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/arrShorthandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/arrShorthandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/callbackParallelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/callbackParallelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/chfPluginTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/chfPluginTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbCaStatsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbChArrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbChArrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbChannelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbChannelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbLockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbLockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbPutLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbScanTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbScanTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbShutdownTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbShutdownTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbStateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbStateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbStressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/dbStressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/recGblCheckDeadbandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/scanIoTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/scanIoTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/testdbConvert.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/db/test/O.linux-x86/testdbConvert.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86/msi.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86/msi.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsAtomicTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsAtomicTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsInlineTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsInlineTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMMIOTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMMIOTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsSpinTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsSpinTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStackTraceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStackTraceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStdlibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStdlibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadHooksTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPoolTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimeZoneTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTypesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsTypesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/macDefExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/macDefExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/libCom/test/O.linux-x86/taskwdTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/arrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/arrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/dbndTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/dbndTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/syncTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/syncTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/tsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/filters/test/O.linux-x86/tsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/analogMonitorTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/analogMonitorTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/arrayOpTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/arrayOpTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/asTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/asTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/compressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/compressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/linkRetargetLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/linkRetargetLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/regressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/std/rec/test/O.linux-x86/regressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Breaktable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Breaktable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/DBD.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/DBD.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Device.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Device.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Driver.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Driver.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Function.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Function.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Menu.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Menu.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Recfield.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Recfield.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Recordtype.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Recordtype.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Registrar.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Registrar.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Snippets.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Snippets.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Variable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/Variable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/macLib.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16-linux32-test/builds/43/tap-master-files/src/tools/test/O.linux-x86/macLib.tap].
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.16-linux32-test #44 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.15-win32-test #100 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-linux32-test #44 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
