2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
To: [email protected]
Date: Thu, 20 Apr 2017 13:42:19 +0200
diff now in the right order, sorry;-)
=== modified file 'src/ioc/rsrv/caservertask.c'
--- src/ioc/rsrv/caservertask.c 2016-05-22 12:38:18 +0000
+++ src/ioc/rsrv/caservertask.c 2017-04-20 11:21:40 +0000
@@ -307,13 +307,17 @@
 #ifdef IP_ADD_MEMBERSHIP
+#if defined(__rtems__)
+           char flag = 1;
+#else
             int flag = 1;
+#endif
             if (setsockopt(beaconSocket, IPPROTO_IP, IP_MULTICAST_LOOP,
                            (char *)&flag, sizeof(flag))<0) {
                 char sockErrBuf[64];
                 epicsSocketConvertErrnoToString (
                             sockErrBuf, sizeof ( sockErrBuf ) );
-                errlogPrintf("rsrv: failed to set mcast loopback\n");
+                errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
 #endif
> On 20 Apr 2017, at 13:27, Heinz Junkes <[email protected]> wrote:
> With RTEMS (4.11.99, aka 4.12) setting the IP_MULTICAST_LOOP for the loopback gives
> Had to use sizeof char as argument for the IP_MULTICAST_LOOP setsockopt call.
> Changed it to
>        int intTrue = 1;
>        if (setsockopt (beaconSocket, SOL_SOCKET, SO_BROADCAST,
>                        (char *)&intTrue, sizeof(intTrue))<0) {
>            cantProceed("CAS: online socket set up error\n");
>            char flag = 1;
> #else
>            int flag = 1;
> #endif
> #endif
>    /* populate the interface address list (default is empty) */
> rtems@epics:~/EPICS/add-rtems-4.12-api$ diff -Naur src/ioc/rsrv/caservertask.c /tmp/caservertask.c
> --- src/ioc/rsrv/caservertask.c	2017-04-20 13:21:40.613544330 +0200
> +++ /tmp/caservertask.c	2017-04-20 13:23:06.537549469 +0200
> @@ -307,17 +307,13 @@
> -#if defined(__rtems__)
> -	    char flag = 1;
> -#else
>             int flag = 1;
> -#endif
> -                errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
> +                errlogPrintf("rsrv: failed to set mcast loopback\n");
> #endif
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Prev: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Next: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
