2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14 #245
To: [email protected]
Date: Mon, 24 Apr 2017 18:17:17 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14/245/display/redirect?page=changes>
Changes:
[Andrew Johnson] Fix for dbCa warning seg-fault
[...truncated 375.35 KB...]
make[4]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/softDev/O.linux-x86_64'
make[4]: Nothing to be done for `tapfiles'.
make[4]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/softDev/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/softDev'
make -C ./testDev tapfiles
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/testDev'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 tapfiles
make[4]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/testDev/O.linux-x86_64'
make[4]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/testDev/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev/testDev'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/dev'
make -C ./vxWorks tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/vxWorks'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/vxWorks/O.linux-x86_64'
make[3]: Nothing to be done for `tapfiles'.
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/vxWorks/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/vxWorks'
make -C ./RTEMS tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS'
make -C ./base tapfiles
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS/base'
make[4]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS/base/O.linux-x86_64'
make[4]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS/base/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS/base'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/RTEMS'
make -C libCom/test tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/libCom/test'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/libCom/test/O.linux-x86_64'
perl epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl epicsCalcTest.t -tap > epicsCalcTest.tap
perl epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl epicsMathTest.t -tap > epicsMathTest.tap
perl epicsEllTest.t -tap > epicsEllTest.tap
perl epicsEnvTest.t -tap > epicsEnvTest.tap
perl epicsErrlogTest.t -tap > epicsErrlogTest.tap
perl epicsStdioTest.t -tap > epicsStdioTest.tap
perl epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl epicsStringTest.t -tap > epicsStringTest.tap
perl epicsTimeTest.t -tap > epicsTimeTest.tap
perl epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl epicsThreadTest.t -tap > epicsThreadTest.tap
perl epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
Recursive epicsThreadOnce() initialization
Thread recurse (0x163adc0) can't proceed, suspending.
perl epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl epicsExitTest.t -tap > epicsExitTest.tap
perl epicsTimerTest.t -tap > epicsTimerTest.tap
perl ringPointerTest.t -tap > ringPointerTest.tap
perl ringBytesTest.t -tap > ringBytesTest.tap
perl epicsEventTest.t -tap > epicsEventTest.tap
perl epicsMutexTest.t -tap > epicsMutexTest.tap
perl macEnvExpandTest.t -tap > macEnvExpandTest.tap
macLib: macro FOO is undefined (expanding string ${FOO})
macLib: macro FOO is undefined (expanding string ${FOO,BAR})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=$(FOO)})
macLib: macro FOO is undefined (expanding string ${FOO,FOO})
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding macro FOO)
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz,FUM})
macLib: macro BAZ is undefined (expanding string ${FOO})
macLib: string ${FOO} is recursive (expanding environment variable FOO)
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding environment variable FOO)
macLib: string ${FOO=$(FOO)} is recursive (expanding environment variable FOO)
macLib: string ${FOO=$(BAR),BAR=$(FOO)} is recursive (expanding environment variable FOO)
perl macLibTest.t -tap > macLibTest.tap
perl taskwdTest.t -tap > taskwdTest.tap
Thread testTask2 (0x16d0690) suspended
perl blockingSockTest.t -tap > blockingSockTest.tap
perl epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/libCom/test/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/libCom/test'
make -C db/test tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/db/test'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/db/test/O.linux-x86_64'
perl callbackTest.t -tap > callbackTest.tap
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/db/test/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/db/test'
make -C ./softIoc tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/softIoc'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/softIoc/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/softIoc/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/softIoc'
make -C ./gdd tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/gdd'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/gdd/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/gdd/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/gdd'
make -C ./cas tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas'
make -C ./build tapfiles
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/build'
make[4]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/build/O.linux-x86_64'
make[4]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/build/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/build'
make -C ./example tapfiles
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example'
make -C ./directoryService tapfiles
make[4]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example/directoryService'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example/directoryService/O.linux-x86_64'
make[5]: Nothing to be done for `tapfiles'.
make[5]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example/directoryService/O.linux-x86_64'
make[4]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example/directoryService'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas/example'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cas'
make -C ./excas tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/excas'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/excas/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/excas/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/excas'
make -C ./cap5 tapfiles
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cap5'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cap5/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cap5/O.linux-x86_64'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src/cap5'
make[1]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.14/workspace/src'
+ prove --parse --failures --color --recurse --ext .tap --exec cat src
src/db/test/O.linux-x86_64/callbackTest.tap ................. ok
src/libCom/test/O.linux-x86_64/blockingSockTest.tap ......... ok
src/libCom/test/O.linux-x86_64/epicsAlgorithmTest.tap ....... ok
src/libCom/test/O.linux-x86_64/epicsCalcTest.tap ............ ok
src/libCom/test/O.linux-x86_64/epicsEllTest.tap ............. ok
src/libCom/test/O.linux-x86_64/epicsEnvTest.tap ............. ok
src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap ..........
not ok  8 - pvt.count == 2
Failed 1/25 subtests
src/libCom/test/O.linux-x86_64/epicsEventTest.tap ........... ok
src/libCom/test/O.linux-x86_64/epicsExitTest.tap ............ ok
src/libCom/test/O.linux-x86_64/epicsMathTest.tap ............ ok
src/libCom/test/O.linux-x86_64/epicsMessageQueueTest.tap .... ok
src/libCom/test/O.linux-x86_64/epicsMutexTest.tap ........... ok
src/libCom/test/O.linux-x86_64/epicsSockResolveTest.tap ..... ok
src/libCom/test/O.linux-x86_64/epicsStdioTest.tap ........... ok
src/libCom/test/O.linux-x86_64/epicsStringTest.tap .......... ok
src/libCom/test/O.linux-x86_64/epicsThreadOnceTest.tap ...... ok
src/libCom/test/O.linux-x86_64/epicsThreadPriorityTest.tap .. ok
src/libCom/test/O.linux-x86_64/epicsThreadPrivateTest.tap ... ok
src/libCom/test/O.linux-x86_64/epicsThreadTest.tap .......... ok
src/libCom/test/O.linux-x86_64/epicsTimeTest.tap ............ ok
src/libCom/test/O.linux-x86_64/epicsTimeZoneTest.tap ........ ok
src/libCom/test/O.linux-x86_64/epicsTimerTest.tap ........... ok
src/libCom/test/O.linux-x86_64/epicsUnitTestTest.tap ........ ok
src/libCom/test/O.linux-x86_64/ipAddrToAsciiTest.tap ........ ok
src/libCom/test/O.linux-x86_64/macEnvExpandTest.tap ......... ok
src/libCom/test/O.linux-x86_64/macLibTest.tap ............... ok
src/libCom/test/O.linux-x86_64/ringBytesTest.tap ............ ok
src/libCom/test/O.linux-x86_64/ringPointerTest.tap .......... ok
src/libCom/test/O.linux-x86_64/taskwdTest.tap ............... ok
Test Summary Report
src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap        (Wstat: 0 Tests: 25 Failed: 1)
  Failed test:  8
Files=29, Tests=2634,  1 wallclock secs ( 0.29 usr  0.01 sys +  0.00 cusr  0.03 csys =  0.33 CPU)
Result: FAIL
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86_64/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/db/test/O.linux-x86_64/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/db/test/O.linux-x86_64/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeZoneTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeZoneTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ipAddrToAsciiTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ipAddrToAsciiTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/macEnvExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/macEnvExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.14/builds/245/tap-master-files/src/libCom/test/O.linux-x86_64/taskwdTest.tap].
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14 #246 APS Jenkins
Jenkins build is still unstable: epics-base-3.14 #244 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15-win32s-test #108 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win64 #292 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is still unstable: epics-base-3.14 #244 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14 #246 APS Jenkins
