Hi Andrew, I'm running into this right now, because it is failing my tests (that try to write to a bo record). Why is none of our tests catching this? (dbPutLinkTest is named like it should.) I would say the dummy method returning OK is the way to go. Other link types might return errors that are worth reporting, and it is certainly a property of the CONSTANT link that a put() operation is never producing an error. Cheers, ~Ralph On Thu, Aug 31, 2017 at 11:35 PM, Andrew Johnson <[email protected]> wrote: [...]
ANJ, 21 Dec 2017 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
