Hi Andrew,
On Fri, Sep 15, 2017 at 8:56 PM, Andrew Johnson <[email protected]> wrote:
I have three statements (four including me) for info items against yours for fields, that's why I kept the approach. But I do not care too much. Did you look at making the two info items into fields instead? I don't The info fields carry only configuration. All state in is the simpvt structure. I will probably still need the simpvt structure to store state. Or are you suggesting to completely remove the private structure and store everything (configuration and state) in fields? I would like to see a comparison of the two approaches, as I'm not I am not against adding fields. All my users said they don't need the settings to be run-time configurable, but it does not hurt if they are. I will try to avoid making them special(), as that would add more code. If a new simmSCAN field is of type menuScan, to what do I have to set the default value (in the dbd) to detect the field not having been set? I need this to not swap the SCAN periods if simmSCAN has not been set. At least one change in recGbl.c seems to be undoing a link support Sorry. I didn't check the documentation and thought I was using the new style constructs. Will fix this. Does the SIMPVT field always point to a struct xsimm? If so the extra() Fine. I was looking at the other ...pvt pointers and tried to be consistent. I prefer to be explicit at this point. I'm getting a build failure on cross-building for MinGW (and this will Will do. My RTEMS build fails in src/std/rec/test: Yup, correct. As I have neither RTEMS nor vxWorks available, I am copy-pasting and hoping for the best. I think that's all for now, I haven't actually looked at or tested the Thanks a lot for the review. I will wait for your comment on the field vs. simpvt issue and do the changes. These will not affect the simulation mode run time behavior. Cheers, ~Ralph
ANJ, 21 Dec 2017 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
