2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 Release Candidate 1
To: Michael Davidsaver <[email protected]>, Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 4 Dec 2017 02:13:55 +0000
Assuming that checking out at the top-level was sufficient I tried to build and it failed.  This is for linux-x86_64.
corvette:local/epics/epics-base>make -sj
../../src/factory/TypeFunc.cpp:19:37: fatal error: dbDefs.h: No such file or directory
 #include "dbDefs.h" // for NELEMENTS
compilation terminated.
make[4]: *** No rule to make target `/usr/local/epics/epics-base/lib/linux-x86_64/libCom.a', needed by `libpvData.a'.  Stop.
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [install.linux-x86_64] Error 2
make[2]: *** [src.install] Error 2
make[1]: *** [pvData.install] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [modules.install] Error 2
This is the complete output without using -sj on make.
make -C ./configure install
make[1]: Entering directory `/usr/local/epics/epics-base/configure'
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/usr/local/epics/epics-base/configure/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/usr/local/epics/epics-base/configure/O.linux-x86_64'
make[1]: Leaving directory `/usr/local/epics/epics-base/configure'
make -C ./src install
make[1]: Entering directory `/usr/local/epics/epics-base/src'
make -C ./tools install
make[2]: Entering directory `/usr/local/epics/epics-base/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/usr/local/epics/epics-base/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Expanding epics-base-linux-x86_64.pc@ to epics-base-linux-x86_64.pc
Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-linux-x86_64.pc
mkdir ../../../lib/pkgconfig
Expanding ../epics-base.pc@ to epics-base.pc
Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/convertRelease.pl
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Installing generated html ../../../html/./EPICS/Getopts.html
mkdir ../../../html/./EPICS
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
Installing generated html ../../../html/./EPICS/Path.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
Installing generated html ../../../html/./EPICS/Readfile.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
Installing generated html ../../../html/./fullPathName.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
Installing generated html ../../../html/./munch.html
make[3]: Leaving directory `/usr/local/epics/epics-base/src/tools/O.linux-x86_64'
make[2]: Leaving directory `/usr/local/epics/epics-base/src/tools'
make -C template/base install
make[2]: Entering directory `/usr/local/epics/epics-base/src/template/base'
perl -CSD /usr/local/epics/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory `/usr/local/epics/epics-base/src/template/base/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/Makefile
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
make[3]: Leaving directory `/usr/local/epics/epics-base/src/template/base/O.linux-x86_64'
make[2]: Leaving directory `/usr/local/epics/epics-base/src/template/base'
make -C template/ext install
make[2]: Entering directory `/usr/local/epics/epics-base/src/template/ext'
mkdir -p O.Common
make[3]: Entering directory `/usr/local/epics/epics-base/src/template/ext/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseExt.pl
Installing ../../../../templates/makeBaseExt/top/Makefile
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/README
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory `/usr/local/epics/epics-base/src/template/ext/O.linux-x86_64'
make[2]: Leaving directory `/usr/local/epics/epics-base/src/template/ext'
make[1]: Leaving directory `/usr/local/epics/epics-base/src'
make -C ./test install
make[1]: Entering directory `/usr/local/epics/epics-base/test'
make[2]: Entering directory `/usr/local/epics/epics-base/test/tools'
mkdir -p O.Common
make[3]: Entering directory `/usr/local/epics/epics-base/test/tools/O.linux-x86_64'
perl -CSD /usr/local/epics/epics-base/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[3]: Leaving directory `/usr/local/epics/epics-base/test/tools/O.linux-x86_64'
make[2]: Leaving directory `/usr/local/epics/epics-base/test/tools'
make[1]: Leaving directory `/usr/local/epics/epics-base/test'
make -C ./modules install
make[1]: Entering directory `/usr/local/epics/epics-base/modules'
make -C ./libcom install
make[2]: Entering directory `/usr/local/epics/epics-base/modules/libcom'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/libcom/configure'
mkdir -p O.Common
make[4]: Entering directory `/usr/local/epics/epics-base/modules/libcom/configure/O.linux-x86_64'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/configure/O.linux-x86_64'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/configure'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/tools/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/tools'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/template/base'
perl -CSD /usr/local/epics/epics-base/modules/libcom/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/template/base/O.linux-x86_64'
make[5]: Nothing to be done for `install'.
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/template/base/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/template/base'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/template/ext'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/libcom/src/template/ext/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/template/ext/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src/template/ext'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/src'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/libcom/test'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/libcom/test/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/libcom/test/tools/O.linux-x86_64'
perl -CSD /usr/local/epics/epics-base/modules/libcom/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/test/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/test/tools'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/test'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/libcom/modules'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/libcom/modules'
make[2]: Leaving directory `/usr/local/epics/epics-base/modules/libcom'
make -C ./ca install
make[2]: Entering directory `/usr/local/epics/epics-base/modules/ca'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/ca/configure'
mkdir -p O.Common
make[4]: Entering directory `/usr/local/epics/epics-base/modules/ca/configure/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/ca/configure/O.linux-x86_64'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/ca/configure'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/ca/src'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/tools/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/tools'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/template/base'
perl -CSD /usr/local/epics/epics-base/modules/ca/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/template/base/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/template/base/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/template/base'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/template/ext'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/ca/src/template/ext/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/template/ext/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src/template/ext'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/ca/src'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/ca/test'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/ca/test/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/ca/test/tools/O.linux-x86_64'
perl -CSD /usr/local/epics/epics-base/modules/ca/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/ca/test/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/ca/test/tools'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/ca/test'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/ca/modules'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/ca/modules'
make[2]: Leaving directory `/usr/local/epics/epics-base/modules/ca'
make -C ./database install
make[2]: Entering directory `/usr/local/epics/epics-base/modules/database'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/database/configure'
mkdir -p O.Common
make[4]: Entering directory `/usr/local/epics/epics-base/modules/database/configure/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/database/configure/O.linux-x86_64'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/database/configure'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/database/src'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/database/src/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/database/src/tools/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/tools'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/database/src/template/base'
perl -CSD /usr/local/epics/epics-base/modules/database/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/database/src/template/base/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/template/base/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/template/base'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/database/src/template/ext'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/database/src/template/ext/O.linux-x86_64'
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/template/ext/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/database/src/template/ext'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/database/src'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/database/test'
make[4]: Entering directory `/usr/local/epics/epics-base/modules/database/test/tools'
mkdir -p O.Common
make[5]: Entering directory `/usr/local/epics/epics-base/modules/database/test/tools/O.linux-x86_64'
perl -CSD /usr/local/epics/epics-base/modules/database/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[5]: Leaving directory `/usr/local/epics/epics-base/modules/database/test/tools/O.linux-x86_64'
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/database/test/tools'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/database/test'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/database/modules'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/database/modules'
make[2]: Leaving directory `/usr/local/epics/epics-base/modules/database'
make -C ./pvData install
make[2]: Entering directory `/usr/local/epics/epics-base/modules/pvData'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/pvData/configure'
mkdir -p O.Common
make[4]: Entering directory `/usr/local/epics/epics-base/modules/pvData/configure/O.linux-x86_64'
Installing CFG file /usr/local/epics/epics-base/cfg/CONFIG_PVDATA_VERSION
mkdir /usr/local/epics/epics-base/cfg
perl -CSD /usr/local/epics/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/pvData/configure/O.linux-x86_64'
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/pvData/configure'
make[3]: Entering directory `/usr/local/epics/epics-base/modules/pvData/src'
mkdir -p O.Common
make[4]: Entering directory `/usr/local/epics/epics-base/modules/pvData/src/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /usr/local/epics/epics-base/bin/linux-x86_64/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="7" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="0" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t /usr/local/epics/epics-base -a linux-x86_64   ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF print.d  ../../src/json/print.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF parseinto.d  ../../src/json/parseinto.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF parseany.d  ../../src/json/parseany.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF parsehelper.d  ../../src/json/parsehelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF bitSetUtil.d  ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvCopy.d  ../../src/copy/pvCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF createRequest.d  ../../src/copy/createRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvTimeStamp.d  ../../src/property/pvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF timeStamp.d  ../../src/property/timeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvEnumerated.d  ../../src/property/pvEnumerated.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvDisplay.d  ../../src/property/pvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvControl.d  ../../src/property/pvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvAlarm.d  ../../src/property/pvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF alarm.d  ../../src/property/alarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF printer.d  ../../src/factory/printer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF StandardPVField.d  ../../src/factory/StandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF StandardField.d  ../../src/factory/StandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF Compare.d  ../../src/factory/Compare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvSubArrayCopy.d  ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF Convert.d  ../../src/factory/Convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVDataCreateFactory.d  ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVUnionArray.d  ../../src/factory/PVUnionArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVUnion.d  ../../src/factory/PVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVStructureArray.d  ../../src/factory/PVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVStructure.d  ../../src/factory/PVStructure.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVScalarArray.d  ../../src/factory/PVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVArray.d  ../../src/factory/PVArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVScalar.d  ../../src/factory/PVScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF PVField.d  ../../src/factory/PVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF FieldCreateFactory.d  ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF TypeFunc.d  ../../src/factory/TypeFunc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF valueBuilder.d  ../../src/pv/valueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvdVersion.d  ../../src/pv/pvdVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF reftrack.d  ../../src/misc/reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF debugPtr.d  ../../src/misc/debugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF pvUnitTest.d  ../../src/misc/pvUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF parseToPOD.d  ../../src/misc/parseToPOD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF typeCast.d  ../../src/misc/typeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF localStaticLock.d  ../../src/misc/localStaticLock.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF status.d  ../../src/misc/status.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF timer.d  ../../src/misc/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF timeFunction.d  ../../src/misc/timeFunction.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF executor.d  ../../src/misc/executor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF event.d  ../../src/misc/event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF serializeHelper.d  ../../src/misc/serializeHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF epicsException.d  ../../src/misc/epicsException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF bitSet.d  ../../src/misc/bitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/usr/local/epics/epics-base/include/compiler/gcc -I/usr/local/epics/epics-base/include/os/Linux -I/usr/local/epics/epics-base/include           -MM -MF byteBuffer.d  ../../src/misc/byteBuffer.cpp
make[4]: Leaving directory `/usr/local/epics/epics-base/modules/pvData/src/O.linux-x86_64'
Installing generic include file /usr/local/epics/epics-base/include/pv/noDefaultMethods.h
mkdir /usr/local/epics/epics-base/include
mkdir /usr/local/epics/epics-base/include/pv
Installing generic include file /usr/local/epics/epics-base/include/pv/lock.h
Installing generic include file /usr/local/epics/epics-base/include/pv/serialize.h
Installing generic include file /usr/local/epics/epics-base/include/pv/bitSet.h
Installing generic include file /usr/local/epics/epics-base/include/pv/byteBuffer.h
Installing generic include file /usr/local/epics/epics-base/include/pv/epicsException.h
Installing generic include file /usr/local/epics/epics-base/include/pv/serializeHelper.h
Installing generic include file /usr/local/epics/epics-base/include/pv/event.h
Installing generic include file /usr/local/epics/epics-base/include/pv/thread.h
Installing generic include file /usr/local/epics/epics-base/include/pv/executor.h
Installing generic include file /usr/local/epics/epics-base/include/pv/timeFunction.h
Installing generic include file /usr/local/epics/epics-base/include/pv/timer.h
Installing generic include file /usr/local/epics/epics-base/include/pv/queue.h
Installing generic include file /usr/local/epics/epics-base/include/pv/status.h
Installing generic include file /usr/local/epics/epics-base/include/pv/sharedPtr.h
Installing generic include file /usr/local/epics/epics-base/include/pv/debugPtr.h
Installing generic include file /usr/local/epics/epics-base/include/pv/localStaticLock.h
Installing generic include file /usr/local/epics/epics-base/include/pv/typeCast.h
Installing generic include file /usr/local/epics/epics-base/include/pv/sharedVector.h
Installing generic include file /usr/local/epics/epics-base/include/pv/templateMeta.h
Installing generic include file /usr/local/epics/epics-base/include/pv/current_function.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvUnitTest.h
Installing generic include file /usr/local/epics/epics-base/include/pv/reftrack.h
Installing generic include file /usr/local/epics/epics-base/include/pv/anyscalar.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvType.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvIntrospect.h
Installing generic include file /usr/local/epics/epics-base/include/pv/valueBuilder.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvData.h
Installing generic include file /usr/local/epics/epics-base/include/pv/convert.h
Installing generic include file /usr/local/epics/epics-base/include/pv/standardField.h
Installing generic include file /usr/local/epics/epics-base/include/pv/standardPVField.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvSubArrayCopy.h
Installing generic include file /usr/local/epics/epics-base/include/pv/typemap.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvdVersion.h
Installing generated generic include file /usr/local/epics/epics-base/include/pv/pvdVersionNum.h
Installing generic include file /usr/local/epics/epics-base/include/pv/factory.h
Installing generic include file /usr/local/epics/epics-base/include/pv/alarm.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvAlarm.h
Installing generic include file /usr/local/epics/epics-base/include/pv/control.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvControl.h
Installing generic include file /usr/local/epics/epics-base/include/pv/display.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvDisplay.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvEnumerated.h
Installing generic include file /usr/local/epics/epics-base/include/pv/timeStamp.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvTimeStamp.h
Installing generic include file /usr/local/epics/epics-base/include/pv/createRequest.h
Installing generic include file /usr/local/epics/epics-base/include/pv/pvCopy.h
Installing generic include file /usr/local/epics/epics-base/include/pv/bitSetUtil.h
Installing generic include file /usr/local/epics/epics-base/include/pv/json.h
make[3]: Leaving directory `/usr/local/epics/epics-base/modules/pvData/src'
make[2]: Leaving directory `/usr/local/epics/epics-base/modules/pvData'
make[1]: Leaving directory `/usr/local/epics/epics-base/modules'
Sent: Sunday, December 3, 2017 8:00 PM
To: Michael Davidsaver; Andrew Johnson; [email protected]
Next problem.
After successfully cloning with https: I tried to check out the R7.0.1-pre1 tag.  I did this successfully at the top-level, and then tried to do it for each submodule with
git submodule foreach git checkout R7.0.1-pre1
It succeeded for ca, database, and libCom, but failed for normativeTypes.
What is the correct way to check out each module at the release which is equivalent to R7.0.1-pre1?  Is it sufficient to do that at the top level, i.e. was the top level R7.0.1-pre1 tag applied when each submodule was at the R7.0.1-pre1 version?
corvette:local/epics/epics-base>git checkout R7.0.1-pre1
M       modules/database
M       modules/libcom
M       modules/normativeTypes
M       modules/pvAccess
M       modules/pvData
M       modules/pvDatabase
M       modules/pva2pva
M       modules/pvaClient
Note: checking out 'R7.0.1-pre1'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b new_branch_name
HEAD is now at e785d87... Set version 7.0.1-pre1 in CONFIG_BASE_VERSION
corvette:local/epics/epics-base>git submodule foreach git checkout R7.0.1-pre1
Entering 'modules/ca'
Previous HEAD position was 5dfd1fc... Export tool configurations as cfg/CONFIG_* files
Entering 'modules/database'
Previous HEAD position was eac8865... Merge 'ignore-siml-failure' into database/master
Entering 'modules/libcom'
Previous HEAD position was 3ca5c20... perl 5.8 compatibility fix
Entering 'modules/normativeTypes'
error: pathspec 'R7.0.1-pre1' did not match any file(s) known to git.
Stopping at 'modules/normativeTypes'; script returned non-zero status.
Mar
Sent: Sunday, December 3, 2017 7:51 PM
> I see the same.  I can't say I've tried this before as "[email protected]:..." is using SSH to pull,
> which isn't usual due to speed.
> Were you trying for "git://github.com/" which is the git native protocol?
> I usually use http for checkouts.
No, I have always cloned with [email protected].  I just tested it with
git clone --recursive [email protected]:/areaDetector/areaDetector
and it worked fine.  It was getting 4.2 MiB/s.
I then tested epics-base using https.
git clone --recursive https://github.com/epics-base/epics-base
That worked.  But it is no faster than ssh, also 4.2 MiB/s.
Sent: Sunday, December 3, 2017 6:44 PM
To: Mark Rivers; Andrew Johnson; [email protected]
On 12/03/2017 05:44 PM, Mark Rivers wrote:
> I would like to get this via git rather than a tar file. I tried the following but it failed.  What am I doing wrong?
> corvette:/usr/local/epics>git clone --recursive [email protected]:epics-base/epics-base
which isn't usual due to speed.  Were you trying for "git://github.com/" which is the git native protocol?
> git clone --recursive https://github.com/epics-base/epics-base.git
Also, as this is as good a point as any.  My usual git configuration to mangle remote
urls so that I can clone via http and automatically push via ssh.
> git config --global --replace-all [email protected]:.pushInsteadOf https://github.com/
> git config --global --add         [email protected]:.pushInsteadOf git://github.com/
> git config --global --replace-all url.git+ssh://git.launchpad.net/.pushInsteadOf https://git.launchpad.net/
> git config --global --add         url.git+ssh://git.launchpad.net/.pushInsteadOf lp:
> git config --global --replace-all url.https://git.launchpad.net/.insteadof lp:
Re: EPICS 7 Release Candidate 1 Mark Rivers
Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Prev: Re: EPICS 7 Release Candidate 1 Mark Rivers
Next: Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
