2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS 7 Release Candidate 1
To: 'Andrew Johnson' <[email protected]>, Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 4 Dec 2017 17:08:55 +0000
Hi Andrew,
> I just added the correct git clone command to the R7-0/1.php page (it was already on the R7-0/index.php page).
Thanks for that.  Those instructions say:
To checkout the latest source code using git use the git command below, which will include some additional files not in the tarfile. Note that the development branch for EPICS 7 is called core/master, and some of the submodules are fetched from Launchpad while others are on Github:
git clone --recursive -b core/master https://git.launchpad.net/epics-base base-7.0
Suppose I do that, but then I don't want to work on the master branch, but rather to work on the R7.01.-rc1 tag.  Can I do that now, or do I need to wait until those tags propagate to Github?
I like to work with a git checkout because it is then easy to find all my local changes, look at file history, etc.  If I were to work from Launchpad as Ralph suggested then would I need to learn how to use bazaar?
Any idea why a git clone using ssh ([email protected]:epics-base/epics/base) does not work, while it works fine for areaDetector/areaDetector?  Is this a permissions problem?
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, December 04, 2017 10:47 AM
> To: Mark Rivers; Michael Davidsaver; [email protected]
> Subject: Re: EPICS 7 Release Candidate 1
> Hi Mark,
> On 12/03/2017 08:21 PM, Mark Rivers wrote:
> > After doing
> > git submodule update
> > git reset --hard R7.0.1-pre1
> > then it built fine.
> Note that the top-level branch that you need to check out to get the
> development version is called core/master. Branch names for the
> submodules are somewhat variable, but 'git submodule update --remote'
> will update them all to their latest commits.
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
RE: EPICS 7 Release Candidate 1 Mark Rivers
Re: EPICS 7 Release Candidate 1 Mark Rivers
Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Re: EPICS 7 Release Candidate 1 Andrew Johnson
Prev: Re: EPICS 7 Release Candidate 1 Andrew Johnson
Next: RE: EPICS 7 Release Candidate 1 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
