2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: more git problems
To: Michael Davidsaver <[email protected]>
Date: Thu, 7 Dec 2017 18:33:26 +0000
Hi Michael,
I will try that tomorrow when I‘m back at work.
Git drives me crazy.
Dirk
Am 07.12.2017 um 18:06 schrieb Michael Davidsaver <[email protected]>:
Dirk,
Calm down and don't delete anything.
Lets first focus on recovery to where you were previously.
When you run:
gitk stash@{0}
You should see the revision which was checked out when you saved this stash.
Run
git checkout -b <tempbranchname> <revision>
This will create a new/temporary branch at the base revision.
Now
git submodule update
Which updates the sub-modules to be at the revision(s) when the super-module
commit was made.
Finally
git stash apply
Which should succeed if everything is really back as it was (wrt. untracked files).
Michael
On 12/07/2017 11:51 AM, Dirk Zimoch wrote:
So how can I check out the latest version from the server to apply my stash on?
On 07.12.2017 17:49, Dirk Zimoch wrote:
On 07.12.2017 17:46, Michael Davidsaver wrote:
On 12/07/2017 11:42 AM, Dirk Zimoch wrote:
My changes are seemingly gone (?) and the module is distressingly empty.
Wrong branch? Maybe.
Your changes are not gone:
Run
git stash list
Your most recent stash is stash@{0}
You can use
gitk stash@{0}
which should show your changes, and which revision they were made
against.
$ git stash list
stash@{0}: WIP on (no branch): f44bfd8 Install databaseModuleDirs.pm
into bin/<host>
more git problems Dirk Zimoch
Re: more git problems Michael Davidsaver
Re: more git problems Dirk Zimoch
Prev: Jenkins build is back to normal : epics-master » linux32 #31 APS Jenkins
Next: Re: base-7.0, can't make on linux Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: more git problems Michael Davidsaver
Next: Build failed in Jenkins: epics-master » mac #30 APS Jenkins
