2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: P4P release prep
To: PVData Developers <[email protected]>, EPICS core-talk <[email protected]>
Date: Thu, 1 Feb 2018 09:31:59 -0800
All,
I'm preparing for an initial release of my P4P module (PVAccess for Python).
So I'd like to ask for test results from anyone who has time+interest in doing
them.  My hope is to do the release next week.
The most basic testing is to build and run the unit tests.  This is described in:
https://mdavidsaver.github.io/p4p/building.html
pip/virtualenv users should note the included requirements-*.txt files
and the "Multiple Python Versions" section.
If you have a PVAccess server, also exercise the get/put/monitor operations
with the include command line tools.
> python -m p4p.client.cli -h
Or programatically from eg. an ipython shell.
> from p4p.client.thread import Context
> ctxt = Context('pva')
> print ctxt.get('pv:name')
further example, and reference at https://mdavidsaver.github.io/p4p/client.html
Those using the RPC operation will want to look at the helper API
https://mdavidsaver.github.io/p4p/rpc.html#client-example
Interested users might want to have a look at the new version of MASAR
save/restore which uses P4P.  A release of this will hopefully be following
soon after this P4P release.  https://github.com/mdavidsaver/masarService
the main documentation page
Re: P4P release prep Williams Jr., Ernest L.
Prev: Re: Problems with parallel make in base 7.0.1.1 on Visual Studio 2015 and Visual Studio 2017 when HOST_OP=NO Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.14-test #26 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS 7 and CS-Studio core developers meeting registration. kunal shroff
Next: Re: P4P release prep Williams Jr., Ernest L.
ANJ, 05 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
