2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS 7: Equivalent to Channel Access Filters
To: [email protected]
Date: Sat, 17 Feb 2018 11:38:50 -0500
On 02/17/2018 09:52 AM, Williams Jr., Ernest L. wrote:
Will there be an equivalent to Channel Access filters in EPICS 7?
https://epics.anl.gov/base/R3-15/5-docs/filters.html
I had added filter plugin support to the pvCopy facility that comes with pvData.
This was implemented in both pvDataCPP and pvDataJava as part of the pvCopy facility.
That means that any channel provider that uses pvCopy would automatically have filter plugin support.
But it was decided that this should not be part of epics7 so I backed out the support.
Here is a condensed description of the support
Field Plugin Filters
pvCopy, which was described above, implements plugin filters that can optionally be attached to fields accessed via pvCopy. Thus, if a channel provider uses pvCopy, it automatically has plugin filter support.
pvCopy itself provides the following plugins: array, deadband, timestamp, and ignore. Other plugins can also be implemented and registered.
The following interfaces are used for implementing plugin filters: PVPlugin, PVFilter, and PVPluginRegistry.
PVPlugin
Method create is called when an instance of pvCopy is created by a channel provider.
interface PVPlugin {
    PVFilter create(String requestValue,PVCopy pvCopy,PVField master);
where
requestValue
The value part of a name=value request option.
pvCopy
The PVCopy to which the PVFilter will be attached.
master
The field in the master PVStructure to which the PVFilter will be attached.
Returns the PVFilter. A null is returned if master or requestValue is not appropriate for the plugin.
PVFilter
The method filter is called whenever pvCopy is used to access a field of the client PVStructure.
interface PVFilter {
    boolean filter(PVField copy,BitSet bitSet,boolean toCopy);
    String getName();
where
copy
The data for copy.
bitSet
The BitSet for copy.
toCopy
(true,false) means copy (from master to copy,from copy to master)
Returns (true,false) if filter modified destination.
PVPluginRegistry
class PVPluginRegistry {
    static void registerPlugin(String name,PVPlugin pvPlugin);
    static PVPlugin find(String name);
The arguments are:
name
The name part of a name=value request option.
pvPlugin
The plugin implementation.
The return value for find is the plugin implementation or null if no plugin with that name has been registered.
Array Plugin
This filter is used to retrieve parts of an array (subarrays and strided subarrays). It is modeled after the array Filter that is provided with epics base starting with the 3.15 releases.
This filter works for both get and put. It works for any scalarArray field. It has not been tested for structureArray or unionArray fields.
The syntax is one of the following:
[array=start]
[array=start:end]
[array=start:increment:end]
start and end both specify an index. increment must be a positive integer.
start and end can be a positive or negative integer. If negative it is relative to the end of the array with -1 meaning the last element.
Suppose that the master array is:
1,2,3,4,5,6,7,8,9,10
Then the get request
[array=0:4]
gets
1,2,3,4,5
The request:
[array=-3:-1]
gets
8,9,10
The request:
[array=2:5]
gets
3,4,5,6
The request:
[array=0:2:-1]
gets
0,2,4,6,8,10
Deadband Plugin
This filter is used to limit the changes to a numeric scalar field that are reported to a client. It is modeled after the deadband Filter that is provided with epics base starting with the 3.15 releases.
This filter only works for numeric scalar fields and only for toCopy.
[deadband=abs:value]
[deadband=rel:value]
where
abs
The value must change by at least this amount since the last value the client received.
rel
The percentage amount the value must change since the last value the client received.
TimeStamp Plugin
This filter is used for accessing a timeStamp field. It is modeled after the timeStamp Filter that is provided with epics base starting with the 3.15 releases.
This filter only works for a timeStamp field.
[timestamp=current]
[timestamp=copy]
where
current
Only works for toCopy=true. Instead of taking the timestamp from master the timeStamp for the client is set to the current time.
copy
Only works for toCopy=false. The timestamp in master is set equal to the timeStamp from the client.
Ignore Plugin
This is not an actual plugin but is handled by pvCopy itself. It is used to suppress sending data to a client unless other fields have changed.
The syntax is:
[ignore=true]
One of the examples shown at the beginning of this section shows how it can be used.
Marty
Cheers,
Ernest
Re: EPICS 7: Equivalent to Channel Access Filters Williams Jr., Ernest L.
Prev: EPICS 7: Equivalent to Channel Access Filters Williams Jr., Ernest L.
Next: Re: EPICS 7: Equivalent to Channel Access Filters Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Next: Re: EPICS 7: Equivalent to Channel Access Filters Williams Jr., Ernest L.
ANJ, 17 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
