2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Build failed in Jenkins: epics-base-3.16-mac-test #203
To: [email protected]
Date: Mon, 28 May 2018 18:23:30 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/203/display/redirect>
Started by upstream project "epics-base-3.16-mac" build number 213
originally caused by:
 Started by upstream project "epics-base-3.16" build number 216
  Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/ws/>
[epics-base-3.16-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins480633615030925339.sh
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ ulimit -c unlimited
+ make -sj tapfiles CROSS_COMPILER_TARGET_ARCHS=
epicsAtomicTest(86217,0x700000081000) malloc: *** error for object 0x7fdc60c008f0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
epicsAtomicTest(86217,0x700000104000) malloc: *** error for object 0x7fdc60c008f8: incorrect checksum for freed object - object was probably modified after being freed.
/bin/sh: line 1: 86217 Abort trap: 6           perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
log client: connected to log server at "127.0.0.1:62688"
Starting iocInit
chfConfigParseStart: plugin pvt alloc failed
Starting iocInit
Starting iocInit
dbConvertJSON: parse error: trailing garbage
                                      0x10
                     (right here) ------^
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
dbJLinkInit: lexical error: invalid char in json text.
                                  {"x":bbbb}
dbJLinkInit: parse error: premature EOF
                                       {"z":{"good":6}
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351,  0 wallclock secs ( 0.05 usr  0.01 sys +  0.01 cusr  0.01 csys =  0.08 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap ..........
Failed 29/50 subtests
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Test Summary Report
epicsAtomicTest.tap        (Wstat: 0 Tests: 21 Failed: 0)
  Parse errors: Bad plan.  You planned 50 tests but ran 21.
Files=40, Tests=4006,  1 wallclock secs ( 0.29 usr  0.05 sys +  0.04 cusr  0.06 csys =  0.44 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:356: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:58: recipe for target 'test-results.darwin-x86' failed
make[2]: *** [test-results.darwin-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'libCom/test.test-results' failed
make[1]: *** [libCom/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.16-mac-test #204 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win64 #215 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-mac-test #204 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: Jenkins build is back to normal : epics-base-3.16-win64 #216 APS Jenkins
ANJ, 28 May 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
