Hi Mark,
On 09/24/2018 05:59 PM, Mark Rivers wrote:
> Just a heads up that I found there is a bug in the mbbo and mbbi records
> in 7.0 today. The problem is that one cannot modify the ZRVL through
> FFVL fields at run-time, which is a problem on our beamlines.
> Andrew found the problem in the special() functions in these records and
> should have a patch soon.
I filed this bug in Launchpad:
https://bugs.launchpad.net/epics-base/+bug/1794196
The git patch is attached ("git apply filename.patch" should work),
please test and let me know the results.
- Andrew
diff --git a/modules/database/src/std/rec/mbbiRecord.c b/modules/database/src/std/rec/mbbiRecord.c
index d04161d..5995288 100644
--- a/modules/database/src/std/rec/mbbiRecord.c
+++ b/modules/database/src/std/rec/mbbiRecord.c
@@ -217,16 +217,6 @@ static long special(DBADDR *paddr, int after)
switch (paddr->special) {
case SPC_MOD:
- if (fieldIndex >= mbbiRecordZRST && fieldIndex <= mbbiRecordFFST) {
- int event = DBE_PROPERTY;
- if (!after) return 0;
- init_common(prec);
- if (prec->val == fieldIndex - mbbiRecordZRST)
- event |= DBE_VALUE | DBE_LOG;
- db_post_events(prec, &prec->val, event);
- return 0;
if (fieldIndex == mbbiRecordSIMM) {
if (!after)
recGblSaveSimm(prec->sscn, &prec->oldsimm, prec->simm);
@@ -234,6 +224,20 @@ static long special(DBADDR *paddr, int after)
recGblCheckSimm((dbCommon *)prec, &prec->sscn, prec->oldsimm, prec->simm);
return 0;
+ if (!after)
+ return 0;
+ init_common(prec);
+ /* Note: ZRVL..FFVL are also SPC_MOD */
+ if (fieldIndex >= mbbiRecordZRST && fieldIndex <= mbbiRecordFFST) {
+ int event = DBE_PROPERTY;
+ if (prec->val == fieldIndex - mbbiRecordZRST)
+ event |= DBE_VALUE | DBE_LOG;
+ db_post_events(prec, &prec->val, event);
+ return 0;
default:
recGblDbaddrError(S_db_badChoice, paddr, "mbbi: special");
return S_db_badChoice;
diff --git a/modules/database/src/std/rec/mbboRecord.c b/modules/database/src/std/rec/mbboRecord.c
index 2e2a35b..e708380 100644
--- a/modules/database/src/std/rec/mbboRecord.c
+++ b/modules/database/src/std/rec/mbboRecord.c
@@ -273,16 +273,6 @@ static long special(DBADDR *paddr, int after)
case SPC_MOD:
- if (fieldIndex >= mbboRecordZRST && fieldIndex <= mbboRecordFFST) {
- if (prec->val == fieldIndex - mbboRecordZRST)
- return 0;
if (fieldIndex == mbboRecordSIMM) {
if (!after)
@@ -290,6 +280,20 @@ static long special(DBADDR *paddr, int after)
return 0;
+ if (!after)
+ return 0;
+ if (fieldIndex >= mbboRecordZRST && fieldIndex <= mbboRecordFFST) {
+ if (prec->val == fieldIndex - mbboRecordZRST)
+ return 0;
default:
recGblDbaddrError(S_db_badChoice, paddr, "mbbo: special");
- RE: Bug in mbbo and mbbi records in Base 7.0 Mark Rivers
- Bug in mbbo and mbbi records in Base 7.0 Mark Rivers
<2018>
2025
<2018>
2025
