2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: hanging test in 3.15
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 8 Nov 2018 09:51:43 +0100
On 02.11.2018 17:43, Johnson, Andrew N. via Core-talk wrote:
Hi Dirk,
On 11/02/2018 05:01 AM, Dirk Zimoch wrote:
It seems I have a hanging test in 3.15 as well
make[3]: Entering directory
`/jenkins/workspace/EPICS-3.15/src/ioc/db/test/O.RHEL7-x86_64'
perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' dbShutdownTest.t
dbPutLinkTest.t dbLockTest.t testdbConvert.t callbackTest.t
callbackParallelTest.t dbStateTest.t dbCaStatsTest.t scanIoTest.t
dbChannelTest.t dbChArrTest.t chfPluginTest.t arrShorthandTest.t
recGblCheckDeadbandTest.t testPutGetTest.t
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbCaStatsTest.t ............ ok
Starting iocInit
Starting iocInit
[Hangs here]
That's scanIoTest, which has had problems on various architectures and
was completely rewritten by Michael for the 3.16 branch in 2015. His
3.16 version probably won't back-port easily to 3.15 though, it uses
some 3.16-only infrastructure IIRC. If it's causing problems you might
want to just disable that test; I'm not sure what else to recommend.
Most of the time it works. In particular when I had re-run the tests manually without even re-compiling, there were no problems. Only last week it was hanging for 3 days once until I aborted it.
Thus I was suspecting some interference like two tests trying to use the same port at the same time.
If I am running the tests for different EPICS versions on the same
Jenkins server, can they destructively interfere if the tests happen to
run at the same time? In that case I better change the Jenkins
configuration to use only 1 worker.
They shouldn't do, although you might want to set EPICS_CA_ADDR_LIST to
localhost and EPICS_CA_AUTO_ADDR_LIST to NO just in case. I usually run
the tests in parallel (make -j4 tapfiles) with no problems, but I'm not
running tests on multiple host-arch's on the same CPU.
- Andrew
I use the different workers to run 3.14, 3.15, 3.16, and 7 in parallel. I do not use 'make -j' because that makes the output in the console log more readable. Thus I do not suspect a problem with multiple host archs but with multiple EPICS versions running at the same time.
I did not know about the "tapfiles" target and even now that you mention it I cannot find documentation about it. I was running "make runtests" but found that Jenkins cannot find failed tests this way. What should I use instead?
Dirk
Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
R7.0.2-rc1 tagged and published at APS Johnson, Andrew N. via Core-talk
Re: R7.0.2-rc1 tagged and published at APS Dirk Zimoch
Prev: Re: Problem with cross-tests Dirk Zimoch
Next: Build failed in Jenkins: EPICS-3.16 #150 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
Next: Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
ANJ, 08 Nov 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
