2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #99
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 11 Mar 2019 21:33:02 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win32-2/99/display/redirect>
[...truncated 6.99 KB...]
Removing bin/win32-x86/softIoc.exe
Removing bin/win32-x86/softIocPVA.exe
Removing bin/win32-x86/tap-to-junit-xml.pl
Removing bin/win32-x86/useManifestTool.pl
Removing cfg/
Removing configure/O.Common/
Removing configure/O.win32-x86/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing modules/RELEASE.win32-x86.local
Removing modules/ca/configure/O.Common/
Removing modules/ca/configure/O.win32-x86/
Removing modules/ca/src/client/O.Common/
Removing modules/ca/src/client/O.win32-x86/
Removing modules/ca/src/perl/O.Common/
Removing modules/ca/src/perl/O.win32-x86/
Removing modules/ca/src/template/O.Common/
Removing modules/ca/src/template/O.win32-x86/
Removing modules/ca/src/tools/O.Common/
Removing modules/ca/src/tools/O.win32-x86/
Removing modules/database/configure/O.Common/
Removing modules/database/configure/O.win32-x86/
Removing modules/database/src/ioc/O.Common/
Removing modules/database/src/ioc/O.win32-x86/
Removing modules/database/src/std/O.Common/
Removing modules/database/src/std/O.win32-x86/
Removing modules/database/src/template/O.Common/
Removing modules/database/src/template/O.win32-x86/
Removing modules/database/src/tools/O.Common/
Removing modules/database/src/tools/O.win32-x86/
Removing modules/database/test/ioc/db/O.Common/
Removing modules/database/test/ioc/db/O.win32-x86/
Removing modules/database/test/ioc/dbtemplate/O.Common/
Removing modules/database/test/ioc/dbtemplate/O.win32-x86/
Removing modules/database/test/std/filters/O.Common/
Removing modules/database/test/std/filters/O.win32-x86/
Removing modules/database/test/std/link/O.Common/
Removing modules/database/test/std/link/O.win32-x86/
Removing modules/database/test/std/rec/O.Common/
Removing modules/database/test/std/rec/O.win32-x86/
Removing modules/database/test/tools/O.Common/
Removing modules/database/test/tools/O.win32-x86/
Removing modules/libcom/RTEMS/O.Common/
Removing modules/libcom/RTEMS/O.win32-x86/
Removing modules/libcom/configure/O.Common/
Removing modules/libcom/configure/O.win32-x86/
Removing modules/libcom/src/O.Common/
Removing modules/libcom/src/O.win32-x86/
Removing modules/libcom/test/O.Common/
Removing modules/libcom/test/O.win32-x86/
Removing modules/libcom/vxWorks/O.Common/
Removing modules/libcom/vxWorks/O.win32-x86/
Removing src/template/base/O.Common/
Removing src/template/base/O.win32-x86/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.win32-x86/
Removing src/tools/O.Common/
Removing src/tools/O.win32-x86/
Removing templates/
Removing test/tools/O.Common/
Removing test/tools/O.win32-x86/
stderr: warning: failed to remove bin/win32-x86/ca.dll: Invalid argument
warning: failed to remove bin/win32-x86/Com.dll: Invalid argument
warning: failed to remove bin/win32-x86/dbCore.dll: Invalid argument
warning: failed to remove bin/win32-x86/dbRecStd.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvAccess.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvAccessCA.dll: Invalid argument
warning: failed to remove bin/win32-x86/pvData.dll: Invalid argument
Also:   hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
		at hudson.remoting.Channel.call(Channel.java:955)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
		at com.sun.proxy.$Proxy100.clean(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
		at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:30)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1270)
		at hudson.scm.SCM.checkout(SCM.java:504)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1810)
		at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:429)
hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout: Removing bin/win32-x86/acctst.exe
Removing bin/win32-x86/antelope.exe
Removing bin/win32-x86/ascheck.exe
Removing bin/win32-x86/assembleSnippets.pl
Removing bin/win32-x86/bldEnvData.pl
Removing bin/win32-x86/caConnTest.exe
Removing bin/win32-x86/caEventRate.exe
Removing bin/win32-x86/caget.exe
Removing bin/win32-x86/cainfo.exe
Removing bin/win32-x86/camonitor.exe
Removing bin/win32-x86/caput.exe
Removing bin/win32-x86/caRepeater.exe
Removing bin/win32-x86/casw.exe
Removing bin/win32-x86/catime.exe
Removing bin/win32-x86/ca_test.exe
Removing bin/win32-x86/check_consist.exe
Removing bin/win32-x86/convertRelease.pl
Removing bin/win32-x86/cvsclean.pl
Removing bin/win32-x86/databaseModuleDirs.pm
Removing bin/win32-x86/dbdExpand.pl
Removing bin/win32-x86/dbdToHtml.pl
Removing bin/win32-x86/dbdToMenuH.pl
Removing bin/win32-x86/dbdToRecordtypeH.pl
Removing bin/win32-x86/dbExpand.pl
Removing bin/win32-x86/depclean.pl
Removing bin/win32-x86/dos2unix.pl
Removing bin/win32-x86/epicsMakeMemFs.pl
Removing bin/win32-x86/expandVars.pl
Removing bin/win32-x86/e_flex.exe
Removing bin/win32-x86/fullPathName.pl
Removing bin/win32-x86/genVersionHeader.pl
Removing bin/win32-x86/installEpics.pl
Removing bin/win32-x86/iocLogServer.exe
Removing bin/win32-x86/libcomModuleDirs.pm
Removing bin/win32-x86/makeBaseApp.pl
Removing bin/win32-x86/makeBaseExt.pl
Removing bin/win32-x86/makeBpt.exe
Removing bin/win32-x86/makeIncludeDbd.pl
Removing bin/win32-x86/makeMakefile.pl
Removing bin/win32-x86/makeTestfile.pl
Removing bin/win32-x86/mkmf.pl
Removing bin/win32-x86/msi.exe
Removing bin/win32-x86/munch.pl
Removing bin/win32-x86/nt.dll
Removing bin/win32-x86/p2p.exe
Removing bin/win32-x86/podRemove.pl
Removing bin/win32-x86/podToHtml.pl
Removing bin/win32-x86/pvAccessIOC.dll
Removing bin/win32-x86/pvaClient.dll
Removing bin/win32-x86/pvcall.exe
Removing bin/win32-x86/pvDatabase.dll
Removing bin/win32-x86/pvget.exe
Removing bin/win32-x86/pvinfo.exe
Removing bin/win32-x86/pvlist.exe
Removing bin/win32-x86/pvmonitor.exe
Removing bin/win32-x86/pvput.exe
Removing bin/win32-x86/qsrv.dll
Removing bin/win32-x86/registerRecordDeviceDriver.pl
Removing bin/win32-x86/replaceVAR.pl
Removing bin/win32-x86/S99caRepeater
Removing bin/win32-x86/S99logServer
Removing cfg/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing templates/
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:828)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #100 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-7.0-win64-test #5 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win32-2 #99 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-7.0 » linux32 #99 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » DLL,win32-2 #100 APS Jenkins via Core-talk
ANJ, 11 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
