Isn't the channel we were originally talking to a standard NTNDArray,
using the areaDetector plugin to serve an areaDetector NDArray over
PVAccess? That plugin uses pvDatabaseCPP IIUC.
- Andrew
On 3/21/19 4:10 PM, Shen, Guobao via Core-talk wrote:
> The union is what we are using for our fast DAQ data from FPGA.
> Our engineers designed the structure that format, and it has similar structure with AD image.
> We do not use a union containing a structure, which might complicate the system.
> In this case, you mean what I got is what I should expect. Right?
> On 3/21/19, 1:20 PM, "Michael Davidsaver" <[email protected]> wrote:
> On 3/21/19 8:43 AM, Shen, Guobao via Core-talk wrote:
> > Hi Core member,
> > Does anyone have experienced to read sub field of a Union structure?
> What you are showing looks like a discriminating/tagged union.
> This is quite different to having a union containing a structure,
> which is maybe what you expect?
> > For example, I have a record:
> > $ pvinfo Test:Data
> > structure
> > uint ArrayId
> > double[] Time
> > union value
> > float[] data1
> > double[] data2
> > If I use
> > $ pvget -r value Test:Data
> > Test:Data
> > structure
> > union value
> > float[] [-0.034794,-0.0417011, …]
> > But if I do it with:
> > $ pvget -r value.data1 Test:Data
> > I got an error on my client like
> > [Test: Data] failed to create channel get: Status [type=FATAL, message=std::bad_alloc]
> > Is that a right way to use it for union?
> > Thanks,
> > Guobao
- Get sub field of Union Shen, Guobao via Core-talk
- Re: Get sub field of Union Michael Davidsaver via Core-talk
- Re: Get sub field of Union Shen, Guobao via Core-talk
<2019>
2025
<2019>
2025
