2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Get sub field of Union
From: "Shen, Guobao via Core-talk" <[email protected]>
To: Marty Kraimer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Mar 2019 17:11:47 +0000
Hi Marty,
I was using our pvaPy for the IOC, and did not use a C++ based IOC, therefore, my IOC did not crash.
Since you have seen the IOC crash, maybe you can give more detailed info there.
Therefore, how about that you create an issue, and add some stack trace details?
Guobao
From: <[email protected]> on behalf of Marty Kraimer via Core-talk <[email protected]>
Reply-To: Marty Kraimer <[email protected]>
Date: Sunday, March 24, 2019 at 3:36 AM
I just tried using pvget with the PVRrestrictedUnion record from exampleCPP/database.
Just like your example it does work with
mrk> pvget -r value PVRrestrictedUnion
PVRrestrictedUnion structure
    union value
        (none)
But with
mrk> pvinfo PVRrestrictedUnion
PVRrestrictedUnion
Server: 10.0.0.19:5075
Type:
    epics:nt/NTUnion:1.0
        union value
            string string
            string[] stringArray
        time_t timeStamp
            long secondsPastEpoch
            int nanoseconds
            int userTag
mrk> pvget -r value.string PVRrestrictedUnion
It does not work and actually causes the IOC to crash.
Is it valid to ask for -r value.string?
Perhaps yes with the expectation that you will  find out if this is the current type of the value field.
If not you  could get valid error message.
Guobao,
Please create a issue in pvDatabaseCPP giving your original message.
Marty
On 3/21/19 11:43 AM, Shen, Guobao via Core-talk wrote:
Hi Core member,
Does anyone have experienced to read sub field of a Union structure?
For example, I have a record:
$ pvinfo Test:Data
structure
    uint ArrayId
    double[] Time
    union value
        float[] data1
        double[] data2
If I use
$ pvget -r value Test:Data
Test:Data
structure
    union value
        float[]  [-0.034794,-0.0417011, …]
But if I do it with:
$ pvget -r value.data1 Test:Data
I got an error on my client like
[Test: Data] failed to create channel get: Status [type=FATAL, message=std::bad_alloc]
Is that a right way to use it for union?
Guobao
Get sub field of Union Shen, Guobao via Core-talk
Re: Get sub field of Union Marty Kraimer via Core-talk
Prev: Re: Get sub field of Union Marty Kraimer via Core-talk
Next: Re: Get sub field of Union Benjamin Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Get sub field of Union Marty Kraimer via Core-talk
ANJ, 28 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
