2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 incompatibility in errMdef.h
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: Dirk Zimoch <[email protected]>, EPICS Core Talk <[email protected]>
Date: Tue, 2 Apr 2019 17:37:11 +0000
Hi Dirk,
On 4/2/19 9:24 AM, Dirk Zimoch via Core-talk wrote:
The function definition errSymbolAdd() (and others) have disappeared from errMdef.h. Thus when compiling a driver including errMdef.h and using errSymbolAdd(), I get a compiler warning because of the missing function prototype.
The prototypes are now in the new header file errSymTbl.h. But simply including the new file instead is no good solution, because then the driver does not compile with older EPICS versions any more.
Instead I have use compiler branches based on EPICS versions. That is a bit inconvenient.
Not sure what you mean by "compiler branches" there.
You could do this:
#include <errMdef.h>
#ifndef M_syd
#include <errSymTbl.h>
#endif
I believe the M_syd macro has not been used since before I started with EPICS. The comment for it said "Sync Data Routines; see sydDefs.h" but that header has not been present in any 3.13 release so I finally deleted that symbol while restructuring the libcom/src/error files.
Alternatively you could do a version number check (see the other epicsVersion.h thread for details) but the above suggestion is simpler and faster.
- Andrew
Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
Prev: [Merge] ~anj/epics-base/+git/base-7.0:loadable-err-syms into epics-base:7.0 Andrew Johnson via Core-talk
Next: How to ensure epicsThread function is running in short-lived environment? Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
Next: Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
