2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0
To: [email protected]
Date: Sat, 27 Apr 2019 06:04:22 -0000
Bruce Hill has proposed merging ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0.
Commit message:
Adds a dbLoadSuspendOnError variable to suspend st.cmd on dbLoad related errors.
Default is False, no change to current behavior.
Suspends the thread reading the st.cmd file on the following:
* db file syntax errors
* unexpanded macros
* invalid DTYP
* invalid enum name
* DESC or other string fields > 40 char
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~bhill/epics-base/+git/epics-base/+merge/366606
Addresses "Stopping IOC boot on failure to load database" suggestion on TechTalk, 4/15/2019.
Your team EPICS Core Developers is requested to review the proposed merge of ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0.
diff --git a/documentation/RELEASE_NOTES.html b/documentation/RELEASE_NOTES.html
index df78360..5b01720 100644
--- a/documentation/RELEASE_NOTES.html
+++ b/documentation/RELEASE_NOTES.html
@@ -29,6 +29,30 @@ release.</p>
 <p>Description</p>
+<h3>Added dbLoadSuspendOnError control</h3>
+<p>When loading database files, unexpanded macros and syntax errors can
+result in one or more records not being loaded and a partly broken IOC.
+By setting dbLoadSuspendOnError to a non-zero value before loading the file,
+the IOC will suspend the thread immediately after printing the error
+message or messages.   This makes it obvious that there was a problem with
+a db file and makes it easy to see the error messages.</p>
+<blockquote><pre>
+var dbLoadSuspendOnError 1      <i>iocsh</i>
+dbLoadSuspendOnError=1          <i>VxWorks</i>
+</pre></blockquote>
+<p>Default is 0, no change to current behavior.</p>
+<p>When set to 1, the thread reading the st.cmd file is suspended on the following errors:</p>
+<ul>
+<li>db file syntax errors</li>
+<li>unexpanded macros</li>
+<li>invalid DTYP</li>
+<li>invalid enum name</li>
+<li>DESC or other string fields &gt; 40 char</li>
+</ul>
 <h1 align="center">EPICS Release 7.0.2.2</h1>
diff --git a/modules/database/src/ioc/dbStatic/dbLexRoutines.c b/modules/database/src/ioc/dbStatic/dbLexRoutines.c
index 9281246..2e09a28 100644
--- a/modules/database/src/ioc/dbStatic/dbLexRoutines.c
+++ b/modules/database/src/ioc/dbStatic/dbLexRoutines.c
@@ -22,6 +22,7 @@
 #include "ellLib.h"
 #include "epicsPrint.h"
 #include "epicsString.h"
+#include "epicsThread.h"
 #include "errMdef.h"
 #include "freeList.h"
 #include "gpHash.h"
@@ -41,6 +42,9 @@
 /*global declarations*/
 epicsShareDef char *makeDbdDepends=0;
+epicsShareDef int dbLoadSuspendOnError=0;
+epicsExportAddress(int,dbLoadSuspendOnError);
 epicsShareDef int dbRecordsOnceOnly=0;
 epicsExportAddress(int,dbRecordsOnceOnly);
@@ -326,6 +330,9 @@ cleanup:
     if(my_buffer) free((void *)my_buffer);
     my_buffer = NULL;
     freeInputFileList();
+    if(status != 0 && dbLoadSuspendOnError) {
+        epicsThreadSuspendSelf();
     return(status);
@@ -354,6 +361,9 @@ static int db_yyinput(char *buf, int max_size)
 		    if (exp < 0) {
 			fprintf(stderr, "Warning: '%s' line %d has undefined macros\n",
 			    pinputFileNow->filename, pinputFileNow->line_num+1);
+                        if(dbLoadSuspendOnError) {
 	    } else {
@@ -1138,6 +1148,10 @@ static void dbRecordField(char *name,char *value)
         epicsPrintf("Can't set \"%s.%s\" to \"%s\" %s\n",
             dbGetRecordName(pdbentry), name, value, msg);
         yyerror(NULL);
+		/* TODO: Find other dbLoad* error handling! */
         return;
diff --git a/modules/database/src/ioc/misc/dbCore.dbd b/modules/database/src/ioc/misc/dbCore.dbd
index 51f9c96..d2776bd 100644
--- a/modules/database/src/ioc/misc/dbCore.dbd
+++ b/modules/database/src/ioc/misc/dbCore.dbd
@@ -16,6 +16,7 @@ variable(CASDEBUG,int)
 variable(dbJLinkDebug,int)
 # Static database access variables
+variable(dbLoadSuspendOnError,int)
 variable(dbRecordsOnceOnly,int)
 variable(dbRecordsAbcSorted,int)
 variable(dbBptNotMonotonic,int)
Re: [Merge] ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0 Martin Konrad via Core-talk
Re: [Merge] ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Jenkins build is still unstable: epics-7.0 » linux32 #116 APS Jenkins via Core-talk
Next: Re: ICALEPCS 2019 Contributions Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 noreply--- via Core-talk
Next: Re: [Merge] ~bhill/epics-base:dbLoadSuspendOnError into epics-base:7.0 Martin Konrad via Core-talk
ANJ, 25 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
