2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1827225] Re: epicsTempName() commit breaks mingw builds
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 01 May 2019 19:27:13 -0000
Both my native MinGW builds (windows-x64-mingw with gcc 7.1.0 from
Strawberry Perl 5.26.2) and cross-builds from RHEL-7.6 still work fine.
Have you seen any error messages from when epicsTempFile.cpp is being
built? This looks similar to my Solaris build failure on Jenkins,
neither compiler appears to be printing an error when compiling that
file, they just don't generate any output.
Hmm, there are actually no object files at all in the
src/libCom/O.<host> directory, is this perhaps a compiler problem
instead? IIRC the epicsTempFile.cpp source just happens to be the first
one that gets compiled, so it just *looks* like that may be the cause. I
suspect my Solaris compilers may have died (see the issue with the
procServ build recently), and I get the exact same symptoms on Windows
if I try to do a native windows-x64 build without having configured the
shell window properly for MSVC.
** Changed in: epics-base
       Status: New => Incomplete
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1827225
Title:
Status in EPICS Base:
  Incomplete
Bug description:
  It looks like the epicsTempName() commit (6201d37 * 3.15) broke the
  mingw builds.
  E.g. on AppVeyor
  mingw32-make[4]: Leaving directory 'C:/projects/epics-base/modules/libcom/src/O.win32-x86-mingw'
  mingw32-make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'e_flex.exe'.  Stop.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1827225/+subscriptions
[Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Prev: [Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Next: [Bug 1827225] Re: epicsTempName() commit breaks mingw builds mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
