2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1666924] Re: remove all uses of XXXSUPFUN typedefs
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 16 May 2019 21:57:42 -0000
It looks like we missed the init() function, which seems like it should
be "long (*init)(void);".  Can we fix w/o a compatibility break?
> struct typed_rset {
>     long number; /* number of support routines */
>     long (*report)(void *precord);
>     long (*init)();
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1666924
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  The OO-like function tables defined in recSup.h, devSup.h, and
  drvSup.h disable type checking by using the typedefs RECSUPFUN,
  DEVSUPFUN, and DRVSUPFUN, respectively, which declare the methods as
  having "any number and type of arguments". For instance, this is in
  devSup.h:
  typedef long (*DRVSUPFUN) ();   /* ptr to driver support function*/
  typedef struct drvet {	/* driver entry table */
  	long		number;		/*number of support routines*/
  	DRVSUPFUN	report;		/*print report*/
  	DRVSUPFUN	init;		/*init support*/
  }drvet;
  Supports have to uses casts to XXXSUPFUN when they fill a xxxet
  structure.
  I think listing the well-known reasons why this is bad would be
  redundant. As an illustration, see the bug recently uncovered by
  Carsten Winkler (http://www.aps.anl.gov/epics/tech-
  talk/2017/msg00347.php).
  I propose to change the definition of these structs so that all the
  methods get their proper type.
  There remains the question how to handle the (implicit) subtype
  polymorphism for things like dbCommon. I propose to handle this by
  forcing support definitions to explicitly cast the argument (e.g.
  dbCommon *precord) to the appropriate subtype; this adds one line of
  code to each support function e.g.
  long process(dbCommon *pdbCommon)
      aoRecord *prec = (aoRecord *)pdbCommon;
      ...use prec from here onward...
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1666924/+subscriptions
Prev: Jenkins build is back to normal : 3.15-pvDatabase-win64s #249 APS Jenkins via Core-talk
Next: Jenkins build is back to stable : epics-pva2pva-linux32 #113 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Bug 1666924] Re: remove all uses of XXXSUPFUN typedefs Andrew Johnson via Core-talk
ANJ, 16 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
